On Tue, 24 Sep 2024, Evans, Richard K. (GRC-H000) via Tech-talk wrote:
Hello,
We have a new project requirement to read status via CAN bus into EPICS. Anyone have any advice on what CAN bus I/O hardware for a PC to buy?
It depends on how you want to interface CAN from PC: PCI, PCIe, USB, ...
For PCI-express, CP602E from MOXA works well.
For PCI, either MOXA CP602U or AdLink PCI7841; however, we had several
AdLinks died (probably because of statics or spikes), while no MOXAs
suffered.
The main question is software:
1. Which OS?
I'm not an expert in Windows, but colleagues had successfully used both
MOXAs and AdLinks with respective drivers from card manufacturers.
For Linux, SocketCAN is the way to go. AdLink, as many other PLX-based
interfaces, is supported by Linux kernel since early 2010s; not sure about
MOXA (stock kernel includes some strange PCI IDs for CP602*), but attached
plx_pci driver works fine (the author, Pavel Cheblakov, had little time to
push it into the kernel repository, thus we used to just compile our
copy).
2. How do you plan to access CAN from EPICS? And that mainly depends on
which communication protocol your CAN hardware employs: CANopen,
DeviceNet, something proprietary/custom?
With best regards,
Dmitry Attachment:
plx_pci_moxa.tar.gz
Description: application/gzip
- Simple CAN bus over ethernet interface Evans, Richard K. (GRC-H000) via Tech-talk
Re: Writing XML directly to area detector's NDAttributesFile PV Matthew Newville via Tech-talk
p4p and numpy 2.0 Torsten Bögershausen via Tech-talk
<2024>
2025
2026
Re: Simple CAN bus over ethernet interface Florian Feldbauer via Tech-talk
Re: Simple CAN bus over ethernet interface Götz Pfeiffer via Tech-talk
<2024>
2025
2026
