1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: OPCUA SSL problem
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 8 Oct 2024 09:59:11 +0200
Hi Karel,
As I wrote earlier, if you want to use the binary distribution with OPC UA security, you need to use a container with an older Linux version. My UA SDK license is for version 1.7.4, which only works against OpenSSLv1. I had to switch OPC UA Security off to get it to compile on the newer systems.
Cheers,
~Ralph
On Tue, 8 Oct 2024 at 09:33, Majer Karel via Tech-talk <[email protected]> wrote:
Hi Ralph,
I have some fairly good news. I built the IOC with the binary distribution and it connects to the server. I cannot read data though, because the IOC ignores security setup and the server is configured in a way that it requires encryption. But I hope that using the full UA SDK will work.
So it seems that the problem is some incompatibility of open62541 client and the server used. I have dumped also working communication of open62541 and B&R OPCUA server and noticed differences in OpenSecureChannelResponse of the two servers. The problematic server does not send Nonce field in the response, but I don’t understand the OPCUA protocol well enough to be able to tell how much of a problem it its.
Best regards,
Karel
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Monday, October 7, 2024 12:02 PM
On Mon, 7 Oct 2024 at 11:04, Majer Karel via Tech-talk <[email protected]> wrote:
I built the device support with UASdk, but the IOC crashes on startup with Segmentation fault:
#!../../bin/linux-x86_64/opcua
OPC UA Client Device Support 0.10.0-dev (-); using Unified Automation C++ Client SDK v1.8.4-632
OPC UA: Autoconnecting sessions
Segmentation fault (core dumped)
That fits exactly the other reports I have received. "Compiles but crashes."
 I could download only evaluation version 1.8.4 of UASdk and noticed that the device support should work up to version 1.7. Is there anything I can try to get this running?
Try the UASDK-based binary distribution tar from GitHub that matches your version of Base (exact match required) and distribution.
Good luck!
~Ralph
RE: OPCUA SSL problem Majer Karel via Tech-talk
Re: OPCUA SSL problem Ralph Lange via Tech-talk
Prev: RE: OPCUA SSL problem Majer Karel via Tech-talk
Next: EPICS-support for Motion Controller from Standa Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: OPCUA SSL problem Majer Karel via Tech-talk
