1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: synApps quadEM build-time code generation
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Iain Marcuson <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 Oct 2024 18:27:37 +0000
Hi Iain,
The EPICS build system does quite a lot of code generation, GNUmake handles that well. I think you’ll need to explain a bit more about what’s different about your process (what does it need to do?) for us to be able to suggest some answers.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 10/11/24, 1:17 PM, "Tech-talk" <[email protected]> wrote:
I am looking to submit a pull request to incorporate a new quadEM IOC into the official package.  The build process uses code-generation, and I don’t see an obvious way to invoke that at build time.  Alternatively, I could generate and commit the code, then send a pull request for that, if that would be better, but I would definitely also want to include the template files used as a basis for the generated code.  What approach would be best for this submission?
Thank you,
Iain Marcuson.
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Re: synApps quadEM build-time code generation Iain Marcuson via Tech-talk
Prev: synApps quadEM build-time code generation Iain Marcuson via Tech-talk
Next: Re: synApps quadEM build-time code generation Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
