1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Help understanding DTYP Soft Timestamp
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Fri, 18 Oct 2024 14:08:07 -0500
On 10/18, Johnson, Andrew N. via Tech-talk wrote:
> The part of that record which copies timestamps is the TSEL link pointing to the .TIME field of the record whose timestamp you want to copy. There is documentation for the TSEL and related TSE fields here, hope this helps:
>     https://urldefense.us/v3/__https://epics.anl.gov/base/R7-0/8-docs/dbCommonRecord.html__;!!G_uCfscf7eWS!eLADVCnYetpN0XAqpFzpPW3IqHxN48gsQg0yYpgSMlUgIxmL8wI5BuvH2QSuaHaZKg0leA62uirY14GwgS-CFw$
Hi, Andrew!
Hmm, I think that's going to be hard to find, and it doesn't seem clear
that you can use a DTYP of "Soft Timestamp" in a stringin record.  I'd
expect documentation on the "Soft Timestamp" DTYP to appear in the
stringin documentation at
  https://urldefense.us/v3/__https://epics.anl.gov/base/R7-0/8-docs/stringinRecord.html__;!!G_uCfscf7eWS!eLADVCnYetpN0XAqpFzpPW3IqHxN48gsQg0yYpgSMlUgIxmL8wI5BuvH2QSuaHaZKg0leA62uirY14GM0NR-nw$
That has a "Device Support" section with a "Device Support for Soft
Records" subsection, and it includes information about the DTYP="Soft
Channel" device support as well as the DTYP="getenv" device support.  I
would expect to find information about the DTYP="Soft Timestamp" device
support here, or if not here, at least a link to information about it
here.
Looking at the ai documentation at
  https://urldefense.us/v3/__https://epics.anl.gov/base/R7-0/8-docs/aiRecord.html__;!!G_uCfscf7eWS!eLADVCnYetpN0XAqpFzpPW3IqHxN48gsQg0yYpgSMlUgIxmL8wI5BuvH2QSuaHaZKg0leA62uirY14EpAdkyTg$
it seems to document the DTYP field in the "Input Specification"
subsection of the "Parameter Fields" section.  This seems different than
the stringin record.  I think it would be good for the reference manual
to be consistent in where it documents fields for each record.
Lewis
Re: Help understanding DTYP Soft Timestamp Ralph Lange via Tech-talk
Help understanding DTYP Soft Timestamp Marco Filho via Tech-talk
Re: Help understanding DTYP Soft Timestamp Johnson, Andrew N. via Tech-talk
Prev: Re: Use EPICS 7.0.* in production? Johnson, Andrew N. via Tech-talk
Next: adding ffmpegServer plugin to IOC John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Help understanding DTYP Soft Timestamp Johnson, Andrew N. via Tech-talk
Next: Re: Help understanding DTYP Soft Timestamp Ralph Lange via Tech-talk
