1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Uniblitz VCM-D1 shutter driver
To: "[email protected] ([email protected])" <[email protected]>
Date: Wed, 30 Oct 2024 13:40:14 +0000
Hi Eddy,
Thanks for sharing the GitHub link which helped me refresh my memory about the shutter driver VCM-D1.
I found Mark’s database file (.db) and looked through it. His approach is a little bit different: instead of using  StreamDevice protocol, Mark (or his colleague) put all simple commands (@, A, B, etc.) in asyn.AOUT to be sent out.
As for the readback value on the current shutter status, I do not see its associated command available in the manual: there seems to be only 8 commands and all those 8 commands are available in the GitHub’s VCMD1.proto.
Cheers,
Yong
NSLS-2 Accelerator Controls
Date: Thursday, October 24, 2024 at 9:49 AM
To: Hu, Yong <[email protected]>, [email protected] <[email protected]>
Subject: AW: Uniblitz VCM-D1 shutter driver
Hey,
thanks! At some point I found this random repository: https://github.com/PeiyuQuan/EPICS-VCM_D1-shutter-driver
And the proto file their was all I needed (although there seems to be a bug in the proto file) and I am able to open and close the shutter.
Unfortunately there does not seem to be a readback value on the current shutter status…
If you can find anyone and figure out if that is possible, that would be great!
Cheers
eddy
Von: Hu, Yong <[email protected]>
Gesendet: Donnerstag, 24. Oktober 2024 14:44
An: Blomley, Edmund (IBPT) <[email protected]>; [email protected]
Betreff: Re: Uniblitz VCM-D1 shutter driver
Hello Eddy,
I remember I received an Asyn (or StreamDevice) file from Mark  quite a few years ago. But I forget which beamline at NSLS-2 was using that shutter. I will ask around and find the file.
Cheers,
Yong
Date: Monday, October 7, 2024 at 10:03 AM
Subject: Uniblitz VCM-D1 shutter driver
Dear Yong, dear Mark,
I stumbled upon this message on the EPICS tech talk archive:
As I would like to integrate the VCM-D1 shutter, can you point me to someone who has a working device support?
Cheers
Eddy
Karlsruhe Institute of Technology (KIT)
Institute for Beam Physics and Technology (IBPT)
Dr. Edmund Blomley
Scientist
Karlsruher Institut für Technologie
Hermann-von-Helmholtz-Platz 1
Gebäude 345
76344 Eggenstein-Leopoldshafen
Germany
Phone: +49 721 608-28676
E-mail: edmund.blomley∂kit.edu
Web: www.ibpt.kit.edu
Registered office:
Kaiserstraße 12, 76131 Karlsruhe, Germany
KIT – The Research University in the Helmholtz Association
Prev: RE: streamDevice configuration issues with serial ports Mark Rivers via Tech-talk
Next: Keithley DMM7510 / DMM6500 Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Uniblitz VCM-D1 shutter driver Blomley, Edmund (IBPT) via Tech-talk
Next: EPICS-support for Motion Controller from Standa Sintschuk, Michael via Tech-talk
