Hi, i'd like to take your advice about procserv error.
I was use very well procserv before, but I don't know why I couldn't use it now. I did install again epics and synapps. Is this the reason why I couldn't use procserv? the error message is : (3_8) [root@psc02 CXIKSS]# procServ -L CXIKSS.log 20000 CXIKSS_st.cmd procServ: spawning daemon process: 4165 (3_8) [root@psc02 CXIKSS]# telnet localhost 20000 Trying ::1... telnet: connect to address ::1: Connection refused Trying 127.0.0.1... Connected to localhost. Escape character is '^]'. @@@ Welcome to procServ (procServ Process Server 2.8.0) @@@ Use ^X to kill the child, auto restart mode is ON, use ^T to toggle auto restart @@@ procServ server PID: 4165 @@@ Server startup directory: /usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/CXIKSS @@@ Child startup directory: /usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/CXIKSS @@@ Child started as: CXIKSS_st.cmd @@@ Child log file: CXIKSS.log @@@ Child "CXIKSS_st.cmd" is SHUT DOWN @@@ procServ server started at: Fri Nov 1 15:26:44 2024 @@@ 0 user(s) and 0 logger(s) connected (plus you) @@@ ^R or ^X restarts the child, ^Q quits the server @@@ Restarting child "CXIKSS_st.cmd" @@@ The PID of new child "CXIKSS_st.cmd" is: 4168 @@@ @@@ @@@ @@@ @@@ procServ: child could not execute: CXIKSS_st.cmd, No such file or directory @@@ @@@ @@@ @@@ @@@ @@@ Received a sigChild for process 4168. Normal exit status = 255 @@@ Current time: Fri Nov 1 15:26:59 2024 @@@ Child process is shutting down, a new one will be restarted shortly @@@ ^R or ^X restarts the child, ^Q quits the server telnet> quit ===================== But I have a st.cmd file in my directory, and it worked very well when I use st.cmd file like this > ./CXIKSS_st.cmd Can you guys please help me about this? Sincerely, Baeg
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
