1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: [EXTERNAL] Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history'
From: "Webb, Brad via Tech-talk" <[email protected]>
Date: Fri, 1 Nov 2024 18:46:51 +0000
Hi
> Can you say more about how your IOCs are being launched?
procServ --name myIOC --logstamp --logfile xxxvar/myIOC/log/myIOC.log --pidfile
xxxvar/myIOC/procServ.pid --chdir xxx/myIOC/iocBoot {port} ./st.cmd'
> Do multiple IOC processes share the same $PWD
No
On Fri, 2024-11-01 at 11:26 -0700, Michael Davidsaver wrote:
> On 11/1/24 06:09, Webb, Brad via Tech-talk wrote:
> > After upgrading to EPICS 7.0.8.1 I see the errors below in the IOC start-up console output.
> >  From the release notes:
> > https://urldefense.us/v3/__https://github.com/epics-base/epics-base/blob/7.0/documentation/RELEASE_NOTES.md*persist-history__;Iw!!G_uCfscf7eWS!fxC6WWyvShbxHs8jPNfGxcc-Yd3gb7wGySPtGjoGKon5HqQERrpNd3FD4NrQvKubT7JRig5xbohNUi8W3jbS$
> > I find this section about setting the environment variable:
> > Persist history
> > Attempt to read and write command to a file (./.iocsh_history by default). Name may be
> > overwritten
> > with by setting $EPICS_IOCSH_HISTFILE to an alternate path, or disabled by setting to an empty
> > string.
> > So, my question is how can this variable be set on a per IOC basis so that each IOC can have its
> > own
> > unique path for the history file?
> Whatever mechanism you are using to launch IOC processes would
> need to compute and set $EPICS_IOCSH_HISTFILE .
> Since you did RtM, I appreciate that this is not by itself a
> useful reply :)
> Do multiple IOC processes share the same $PWD and/or does
> an IOC not have permission to create files in $PWD ?
IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Webb, Brad via Tech-talk
Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Michael Davidsaver via Tech-talk
Prev: Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Michael Davidsaver via Tech-talk
Next: Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
