Hi All,
We are using in ALS various drivers which are based on Asyn. Some of them do not auto reconnect. I wanted to consult with you what could be done in order to make them auto reconnect. 1. Galil (Galil-4-0-02) motion controller driver. When the connection is lost it reconnects and crashes straight after with the message: free(): invalid size or munmap_chunk(): invalid pointer example: Disconnected from DMC4040 Rev 1.3i-SER at 131.243.196.71 connected_=1 Connected to DMC4040 Rev 1.3i-SER at 131.243.196.71 connected set false Disconnected from DMC4040 Rev 1.3i-SER at 131.243.196.71 2024/10/30 15:17:58.330 GALILSYNC0 -1 autoConnect could not connect: Can't connect to 131.243.196.71:23 TCP: Connection timed out 2024/10/30 15:20:09.411 GALILSYNC0 -1 port is now connected connected_=1 Connected to DMC4040 Rev 1.3i-SER at 131.243.196.71 free(): invalid size Aborted (core dumped) 2. Vimba ccd camera driver simply does not reconnect when the connection with the camera is lost. We use the driver for the Manta G-235B camera (with the Allied Vision 1800 U-501 NIR cheap) and also older cameras Manta_G-145 . We used before the Prosilica driver what was doing the auto connect but Vimba does not do that. 3. Custom stream device support driver which uses the call: drvAsynIPPortConfigure("custom_device", "HW_dev:8003",0,0,0) The ioc does not reconnect when the underlying hardware is off for a longer time (2-3 hours) and powered back. Best Regards Mirek
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
