Hi Mark,
This is an XPS-D8, so it makes sense that the Aux isn't working based on that.
Here's my motor.substitutions.xps5 contents. I was getting errors explicitly related to the axes that aren't configured in the Newport (I only have motors attached to 6, 7, and 8 right now), so I commented those out: file "$(MOTOR)/db/basic_asyn_motor.db" { pattern {P, N, M, DTYP, PORT, ADDR, DESC, EGU, DIR, VELO, VBAS, ACCL, BDST, BVEL, BACC, MRES, PREC, DHLM, DLLM, INIT} #{18ID_D_Newport:, 1, "m$(N)", "asynMotor", XPS1, 0, "Dummy1", degrees, Neg, 4.0, 0.1, .5, 0, 1, .2, .00025, 4, 190, -190, ""} #{18ID_D_Newport:, 2, "m$(N)", "asynMotor", XPS1, 1, "Dummy1", degrees, Neg, 4.0, 0.1, .5, 0, 1, .2, .00025, 4, 190, -190, ""} #{18ID_D_Newport:, 3, "m$(N)", "asynMotor", XPS1, 2, "Dummy1", degrees, Neg, 4.0, 0.1, .5, 0, 1, .2, .00025, 4, 190, -190, ""} #{18ID_D_Newport:, 4, "m$(N)", "asynMotor", XPS1, 3, "Dummy1", degrees, Neg, 4.0, 0.1, .5, 0, 1, .2, .00025, 4, 190, -190, ""} #{18ID_D_Newport:, 5, "m$(N)", "asynMotor", XPS1, 4, "Dummy1", degrees, Neg, 4.0, 0.1, .5, 0, 1, .2, .00025, 4, 190, -190, ""} {18ID_D_Newport:, 6, "m$(N)", "asynMotor", XPS1, 5, "size Rot", deg, Pos, 20., 0, 0.25, 0, 1, .2, 0.02, 2, 1000000.0, -1000000.0, ""} {18ID_D_Newport:, 7, "m$(N)", "asynMotor", XPS1, 6, "size X", mm, Pos, 50., 0, 0.25, 0, 1, .2, 0.0005, 4, 25.0, -25.0, ""} {18ID_D_Newport:, 8, "m$(N)", "asynMotor", XPS1, 7, "size Y", mm, Pos, 50., 0, 0.25, 0, 1, .2, 0.0005, 4, 25.0, -25.0, ""} }
file "$(MOTOR)/db/XPS_extra.db" { pattern {P, R, PORT, ADDR} #{18ID_D_Newport:, m1, XPS1 0} #{18ID_D_Newport:, m2, XPS1 1} #{18ID_D_Newport:, m3, XPS1 2} #{18ID_D_Newport:, m4, XPS1 3} #{18ID_D_Newport:, m5, XPS1 4} {18ID_D_Newport:, m6, XPS1 5} {18ID_D_Newport:, m7, XPS1 6} {18ID_D_Newport:, m8, XPS1 7} }
file "$(MOTOR)/db/profileMoveController.template" { pattern {P, R, PORT, NAXES, NPOINTS, NPULSES, TIMEOUT} {18ID_D_Newport:, Prof1:, XPS1, 8, 2000, 2000, 1} }
file "$(MOTOR)/db/profileMoveControllerXPS.template" { pattern {P, R, PORT, NAXES, NPOINTS, NPULSES, TIMEOUT} {18ID_D_Newport:, Prof1:, XPS1, 8, 2000, 2000, 1} }
file "$(MOTOR)/db/profileMoveAxis.template" { pattern {P, R, M, PORT, ADDR,NPOINTS, NREADBACK, MOTOR, PREC, TIMEOUT} #{18ID_D_Newport:, Prof1:, 1, XPS1, 0, 2000, 2000, 18ID_D_Newport:m1, 3, 1} #{18ID_D_Newport:, Prof1:, 2, XPS1, 1, 2000, 2000, 18ID_D_Newport:m2, 4, 1} #{18ID_D_Newport:, Prof1:, 3, XPS1, 2, 2000, 2000, 18ID_D_Newport:m3, 4, 1} #{18ID_D_Newport:, Prof1:, 4, XPS1, 3, 2000, 2000, 18ID_D_Newport:m4, 4, 1} #{18ID_D_Newport:, Prof1:, 5, XPS1, 4, 2000, 2000, 18ID_D_Newport:m5, 4, 1} {18ID_D_Newport:, Prof1:, 6, XPS1, 5, 2000, 2000, 18ID_D_Newport:m6, 4, 1} {18ID_D_Newport:, Prof1:, 7, XPS1, 6, 2000, 2000, 18ID_D_Newport:m6, 4, 1} {18ID_D_Newport:, Prof1:, 8, XPS1, 7, 2000, 2000, 18ID_D_Newport:m6, 4, 1} }
file "$(MOTOR)/db/profileMoveAxisXPS.template" { pattern {P, R, M, PORT, ADDR,NPOINTS, NREADBACK, PREC, TIMEOUT} #{18ID_D_Newport:, Prof1:, 1, XPS1, 0, 2000, 2000, 3, 1} #{18ID_D_Newport:, Prof1:, 2, XPS1, 1, 2000, 2000, 4, 1} #{18ID_D_Newport:, Prof1:, 3, XPS1, 2, 2000, 2000, 4, 1} #{18ID_D_Newport:, Prof1:, 4, XPS1, 3, 2000, 2000, 4, 1} #{18ID_D_Newport:, Prof1:, 5, XPS1, 4, 2000, 2000, 4, 1} {18ID_D_Newport:, Prof1:, 6, XPS1, 5, 2000, 2000, 4, 1} {18ID_D_Newport:, Prof1:, 7, XPS1, 6, 2000, 2000, 4, 1} {18ID_D_Newport:, Prof1:, 8, XPS1, 7, 2000, 2000, 4, 1} }
Here's the current set of errors with this file: iocInit Starting iocInit ############################################################################ ## EPICS R7.0.8 ## Rev. 2024-03-01T16:24-0600 ## Rev. Date build date/time: ############################################################################ drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. 2024/11/12 15:48:16.669 18ID_D_Newport:Prof1:FixedTime devAsynFloat64::processCallbackOutput process write error 2024/11/12 15:48:16.670 18ID_D_Newport:Prof1:Acceleration devAsynFloat64::processCallbackOutput process write error 2024/11/12 15:48:16.670 18ID_D_Newport:Prof1:TimeMode devAsynInt32::processCallbackOutput process write error 2024/11/12 15:48:16.670 18ID_D_Newport:Prof1:MoveMode devAsynInt32::processCallbackOutput process write error 2024/11/12 15:48:16.670 18ID_D_Newport:Prof1:NumAxes devAsynInt32::processCallbackOutput process write error 2024/11/12 15:48:16.670 18ID_D_Newport:Prof1:NumPoints devAsynInt32::processCallbackOutput process write error 2024/11/12 15:48:16.670 18ID_D_Newport:Prof1:NumPulses devAsynInt32::processCallbackOutput process write error 2024/11/12 15:48:16.670 18ID_D_Newport:Prof1:StartPulses devAsynInt32::processCallbackOutput process write error 2024/11/12 15:48:16.670 18ID_D_Newport:Prof1:EndPulses devAsynInt32::processCallbackOutput process write error
All the best.
- Jesse
---- Jesse Hopkins, PhD Deputy Director BioCAT, Sector 18 Advanced Photon Source
Hi Jesse,
- 2024/11/12 14:15:20.402 XPSAxis:getPID:. XPS XPS1 axis 5 corrector type is NoCorrector. Cannot get PID.
That message is normal for axes without feedback, not a problem.
- 2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:FixedTime devAsynFloat64::processCallbackOutput process write error
I don’t know what is causing those errors. How have you changed
motor.substitutions.xps5?
- I also tried enabling the Aux configuration and still get the same kinds of errors:
- 2024/11/12 14:15:11.994 drvXPSAsynAux::XPSAuxPoller error calling GPIOAnalogGet=-8
What version of the XPS is this, XPS-C8, XPS-Q8, or XPS-D8? As I recall the XPSAux code needs work to run on the XPS-D8.
- The only output we use from the XPS controllers at the moment is the PCO, I don't know if this will affect our ability to use that
or not. If not, I'm happy to just leave it disabled/ignore it.
The XPSAux code is not needed for the PCO output, or the trigger pulse output from trajectory scans/profile moves. It is only needed for direct digital I/O and analog I/O.
Thanks for the quick response! Changing to the correct version of the config commands seems to have fixed most of the issues. There are still a few more things I'm not sure about. After configuring one of the axes I get the following message.
Should I be concerned? This motor doesn't have encoders, so my suspicion is it's about that:
XPSCreateAxis("XPS1",5,"Group6.Pos", "50")
And on iocInit I get some errors about the profile:
iocInit
Starting iocInit
## EPICS R7.0.8
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:Acceleration devAsynFloat64::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:TimeMode devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:MoveMode devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:M1UseAxis devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:M2UseAxis devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:M3UseAxis devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:M4UseAxis devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:M5UseAxis devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:NumAxes devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:NumPoints devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:NumPulses devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:StartPulses devAsynInt32::processCallbackOutput process write error
2024/11/12 14:15:20.944 18ID_D_Newport:Prof1:EndPulses devAsynInt32::processCallbackOutput process write error
Here's the full IOC startup in case it's useful:
(main) biocat@dalek:/opt/epics/epics_iocs/soft_iocs/newport_test/iocBoot/iocnewport_test$ ./st.cmd
#!../../bin/linux-x86_64/newport_test
#errlogInit(5000)
< envPaths
epicsEnvSet("IOC","iocnewport_test")
epicsEnvSet("TOP","/opt/epics/epics_iocs/soft_iocs/newport_test")
epicsEnvSet("SUPPORT","/opt/epics/synApps_6_3/support")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("ALIVE","/opt/epics/synApps_6_3/support/alive-R1-4-1")
epicsEnvSet("ASYN","/opt/epics/synApps_6_3/support/asyn-R4-44-2")
epicsEnvSet("AUTOSAVE","/opt/epics/synApps_6_3/support/autosave-R5-11")
epicsEnvSet("BUSY","/opt/epics/synApps_6_3/support/busy-R1-7-4")
epicsEnvSet("CALC","/opt/epics/synApps_6_3/support/calc-R3-7-5")
epicsEnvSet("CAMAC","/opt/epics/synApps_6_3/support/camac-R2-7-5")
epicsEnvSet("CAPUTRECORDER","/opt/epics/synApps_6_3/support/caputRecorder-R1-7-6")
epicsEnvSet("DAC128V","/opt/epics/synApps_6_3/support/dac128V-R2-10-1")
epicsEnvSet("DELAYGEN","/opt/epics/synApps_6_3/support/delaygen-R1-2-4")
epicsEnvSet("DEVIOCSTATS","/opt/epics/synApps_6_3/support/iocStats-3-1-16")
epicsEnvSet("ETHERIP","/opt/epics/synApps_6_3/support/ether_ip-ether_ip-3-3")
epicsEnvSet("GALIL","/opt/epics/synApps_6_3/support/Galil-4-0-02")
epicsEnvSet("IP","/opt/epics/synApps_6_3/support/ip-R2-22")
epicsEnvSet("IP330","/opt/epics/synApps_6_3/support/ip330-R2-10")
epicsEnvSet("IPAC","/opt/epics/synApps_6_3/support/ipac-2-16")
epicsEnvSet("IPUNIDIG","/opt/epics/synApps_6_3/support/ipUnidig-R2-12")
epicsEnvSet("LABJACK","/opt/epics/synApps_6_3/support/LabJack-master")
epicsEnvSet("LOVE","/opt/epics/synApps_6_3/support/love-R3-2-9")
epicsEnvSet("LUA","/opt/epics/synApps_6_3/support/lua-R3-1")
epicsEnvSet("MCA","/opt/epics/synApps_6_3/support/mca-R7-10")
epicsEnvSet("MEASCOMP","/opt/epics/synApps_6_3/support/measComp-master")
epicsEnvSet("MODBUS","/opt/epics/synApps_6_3/support/modbus-R3-3")
epicsEnvSet("MOTOR","/opt/epics/synApps_6_3/support/motor-R7-3-1")
epicsEnvSet("OPTICS","/opt/epics/synApps_6_3/support/optics-R2-14")
epicsEnvSet("SCALER","/opt/epics/synApps_6_3/support/scaler-4-1")
epicsEnvSet("SNCSEQ","/opt/epics/synApps_6_3/support/sequencer-mirror-R2-2-9")
epicsEnvSet("SOFTGLUE","/opt/epics/synApps_6_3/support/softGlue-R2-8-4")
epicsEnvSet("SOFTGLUEZYNQ","/opt/epics/synApps_6_3/support/softGlueZynq-R2-0-5")
epicsEnvSet("SSCAN","/opt/epics/synApps_6_3/support/sscan-R2-11-6")
epicsEnvSet("STD","/opt/epics/synApps_6_3/support/std-R3-6-4")
epicsEnvSet("STREAM","/opt/epics/synApps_6_3/support/StreamDevice-2-8-24")
epicsEnvSet("VAC","/opt/epics/synApps_6_3/support/vac-R1-9-2")
epicsEnvSet("VME","/opt/epics/synApps_6_3/support/vme-R2-9-5")
epicsEnvSet("XXX","/opt/epics/synApps_6_3/support/xxx-R6-3")
epicsEnvSet("YOKOGAWA_DAS","/opt/epics/synApps_6_3/support/Yokogawa_DAS-R2-0-2")
epicsEnvSet("ALLENBRADLEY","/opt/epics/synApps_6_3/support/allenBradley-2-3")
epicsEnvSet("ULDAQ","/opt/epics/synApps_6_3/support/measComp-R4-2/libuldaq-1.2.1")
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in this build from CARS
dbLoadDatabase("../../dbd/iocnewport_testLinux.dbd")
iocnewport_testLinux_registerRecordDeviceDriver(pdbbase)
### Motors
dbLoadTemplate "motor.substitutions.xps5"
#dbLoadTemplate "XPSAux.substitutions"
# asyn port, IP address, IP port, number of axes,
# active poll period (ms), idle poll period (ms),
# enable set position, set position settling time (ms)
XPSCreateController("XPS1", "164.54.204.74", 5001, 8, 10, 500, 0, 500)
#asynSetTraceIOMask("XPS1", 0, 2)
#asynSetTraceMask("XPS1", 0, 255)
# asynPort, IP address, IP port, poll period (ms)
#XPSAuxConfig("XPS_AUX1", "164.54.204.74", 5001, 50)
#asynSetTraceIOMask("XPS_AUX1", 0, 2)
#asynSetTraceMask("XPS_AUX1", 0, 255)
# XPS asyn port, axis, groupName.positionerName, stepSize
#XPSCreateAxis("XPS1",0,"GROUP.PHI", "1000")
# PR50PP
# ILS50PP
XPSCreateAxis("XPS1",6,"Group7.Pos", "2000")
# ILS50PP
XPSCreateAxis("XPS1",7,"Group8.Pos", "5000")
# XPS asyn port, max points, FTP username, FTP password
# Note: this must be done after configuring axes
XPSCreateProfile("XPS1", 2000, "Administrator", "Administrator")
iocInit
Starting iocInit
## EPICS R7.0.8
2024/11/12 14:15:11.994 drvXPSAsynAux::XPSAuxPoller error calling GPIODigitalGet=-8
2024/11/12 14:15:11.995 drvXPSAsynAux::XPSAuxPoller error calling GPIODigitalGet=-8
2024/11/12 14:15:12.046 drvXPSAsynAux::XPSAuxPoller error calling GPIOAnalogGet=-8
The only output we use from the XPS controllers at the moment is the PCO, I don't know if this will affect our ability to use that or not. If not, I'm happy to just leave it disabled/ignore it.
Jesse Hopkins, PhD
Deputy Director
BioCAT, Sector 18
Hi Jesse,
I suggest commenting out this line, at least to start:
That is used only for auxiliary analog and digital I/O, not for motor control. It is generating a lot of your error messages.
IOC:m6Offset devAsynFloat64::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_OFFSET
recGblRecordError: ao: init_record Error (514,11) PV: IOC:m6Offset
IOC:m6Resolution devAsynFloat64::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_RESOLUTION
The above messages are because you are using the old Model 2 driver via the XPSConfig command. You should use the new Model 3
driver, which uses XPSCreateController. Look at st.cmd.xps5 for an example.
On Behalf Of Jesse Hopkins via Tech-talk
Sent: Tuesday, November 12, 2024 1:48 PM
To: EPICS Tech Talk <[email protected]>
Subject: Help with motorNewport config
I'm attempting to set up a Newport XPS-D8 using the motorNewport module, and having some trouble. Basically, the configuration seems to go fine, but as soon as I call iocInit I
get a bunch of error messages. I suspect I'm not actually configuring it correctly, there are ~5 XPS start.cmd files in the example IOC, and they're all a bit different, so I wasn't quite sure how to proceed there. Any help anyone can provide would be greatly
appreciated!
XPS firmware: XPS-D-N13019
Here's an abbreviated output from trying to start the IOC.
#errlogInit(5000)
< envPaths
### Motors
dbLoadTemplate "motor.substitutions.xps3"
# asyn port, IP address, IP port, number of axes, active poll period (ms), idle poll period (ms)
#XPSConfig("XPS1", "164.54.204.74", 5001, 8, 20, 500)
##### Maybe this
# cards (total controllers)
XPSSetup(1)
# card, IP, PORT, number of axes, active poll period (ms), idle poll period (ms)
XPSConfig(0, "164.54.204.74", 5001, 8, 10, 5000)
# asyn port, driver name, controller index, max. axes)
drvAsynMotorConfigure("XPS1", "motorXPS", 0, 8)
XPSInterpose("XPS1")
# card, axis, groupName.positionerName, stepSize
# PR50PP
XPSConfigAxis(0,5,"Group6.Pos", 50)
# ILS50PP
XPSConfigAxis(0,6,"Group7.Pos", 2000)
# ILS50PP
XPSConfigAxis(0,7,"Group8.Pos", 5000)
#XPSEnableSetPosition(XPS1, 0)
#XPSSetPositionSettlingTime(XPS1, 200)
#dbLoadRecords("$(MOTOR)/motorApp/Db/trajectoryScan.db", "P=IOC:,R=traj1,NAXES=2,NELM=2000,NPULSE=2000,DONPV=13LAB:str:EraseStart,DONV=1,DOFFPV=13LAB:str:StopAll,DOFFV=1")
iocInit
Starting iocInit
## EPICS R7.0.8
recGblRecordError: ao: init_record Error (514,11) PV: IOC:m6Resolution
IOC:m7Offset devAsynFloat64::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_OFFSET
recGblRecordError: ao: init_record Error (514,11) PV: IOC:m7Offset
IOC:m7Resolution devAsynFloat64::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_RESOLUTION
recGblRecordError: ao: init_record Error (514,11) PV: IOC:m7Resolution
IOC:m8Offset devAsynFloat64::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_OFFSET
recGblRecordError: ao: init_record Error (514,11) PV: IOC:m8Offset
IOC:m8Resolution devAsynFloat64::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_RESOLUTION
recGblRecordError: ao: init_record Error (514,11) PV: IOC:m8Resolution
IOC:m6Direction devAsynInt32::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_DIRECTION
IOC:m7Direction devAsynInt32::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_DIRECTION
IOC:m8Direction devAsynInt32::initCommon drvUserCreate drvmotorAsyn::drvUserCreate, unknown command=MOTOR_REC_DIRECTION
2024/11/12 13:27:13.484 motorAxisSetDouble: XPS does not support setting encoder ratio
2024/11/12 13:27:13.484 devMotorAsyn::init_controller, IOC:m6 failed to set encoder ratio to inf
2024/11/12 13:27:13.486 motorAxisSetDouble: XPS does not support setting encoder ratio
2024/11/12 13:27:13.486 devMotorAsyn::init_controller, IOC:m7 failed to set encoder ratio to inf
2024/11/12 13:27:13.487 motorAxisSetDouble: XPS does not support setting encoder ratio
2024/11/12 13:27:13.487 devMotorAsyn::init_controller, IOC:m8 failed to set encoder ratio to inf
2024/11/12 13:27:13.501 drvXPSAsynAux::XPSAuxPoller error calling GPIOAnalogGet=-8
2024/11/12 13:27:13.942 drvXPSAsynAux::XPSAuxPoller error calling GPIODigitalGet=-8
2024/11/12 13:27:13.991 IOC:XPSAux1Bi0 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.992 IOC:XPSAux1Bi1 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.992 IOC:XPSAux1Bi2 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.993 drvXPSAsynAux::XPSAuxPoller error calling GPIOAnalogGet=-8
2024/11/12 13:27:13.993 IOC:XPSAux1Bi3 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.994 drvXPSAsynAux::XPSAuxPoller error calling GPIODigitalGet=-8
2024/11/12 13:27:13.994 IOC:XPSAux1Bi4 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.995 drvXPSAsynAux::XPSAuxPoller error calling GPIODigitalGet=-8
2024/11/12 13:27:13.995 IOC:XPSAux1Bi5 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.996 IOC:XPSAux1Bi6 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.996 drvXPSAsynAux::XPSAuxPoller error calling GPIODigitalGet=-8
2024/11/12 13:27:13.997 IOC:XPSAux1Bi7 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.997 IOC:XPSAux2Bi0 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.998 IOC:XPSAux2Bi1 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.998 IOC:XPSAux2Bi2 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:13.999 IOC:XPSAux2Bi3 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.008 IOC:XPSAux2Bi4 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.009 IOC:XPSAux2Bi5 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.012 IOC:XPSAux4Bi0 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.012 IOC:XPSAux4Bi1 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.012 IOC:XPSAux4Bi2 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.013 IOC:XPSAux4Bi3 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.013 IOC:XPSAux4Bi4 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.014 IOC:XPSAux4Bi5 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.014 IOC:XPSAux4Bi6 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.015 IOC:XPSAux4Bi7 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.015 IOC:XPSAux4Bi8 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.015 IOC:XPSAux4Bi9 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.017 IOC:XPSAux4Bi10 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.024 IOC:XPSAux4Bi11 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.025 IOC:XPSAux4Bi12 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.025 IOC:XPSAux4Bi13 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.026 IOC:XPSAux4Bi14 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.026 IOC:XPSAux4Bi15 devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.026 IOC:XPSAux1Li devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.027 IOC:XPSAux2Li devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
2024/11/12 13:27:14.028 IOC:XPSAux4Li devAsynUInt32Digital::processCallbackInput process read error drvXPSAsynAux::readUInt32D error calling GPIODigitalGet=-8
# This IOC does not use save/restore, so set values of some PVs
#dbpf("IOC:m1.RTRY", "0")
#dbpf("IOC:m1.TWV", "0.1")
#dbpf("IOC:m2.RTRY", "0")
#dbpf("IOC:m2.TWV", "0.1")
#dbpf("IOC:m3.RTRY", "0")
#dbpf("IOC:m3.TWV", "0.1")
#dbpf("IOC:m4.RTRY", "0")
#dbpf("IOC:m4.TWV", "0.1")
#dbpf("IOC:m5.RTRY", "0")
#dbpf("IOC:m5.TWV", "0.1")
dbpf("IOC:m6.RTRY", "0")
DBF_SHORT: 0 = 0x0
dbpf("IOC:m6.TWV", "0.1")
DBF_DOUBLE: 0.1
dbpf("IOC:m7.RTRY", "0")
DBF_SHORT: 0 = 0x0
dbpf("IOC:m7.TWV", "0.1")
DBF_DOUBLE: 0.1
dbpf("IOC:m8.RTRY", "0")
DBF_SHORT: 0 = 0x0
dbpf("IOC:m8.TWV", "0.1")
DBF_DOUBLE: 0.1
2024/11/12 13:27:14.047 drvXPSAsynAux::XPSAuxPoller error calling GPIOAnalogGet=-8
Here's the contents of my motor.substitutions file:
pattern
{IOC:, 6, "m$(N)", "asynMotor", XPS1, 5, "size Rot", deg, Pos, 20., 0, 0.25, 0, 1, .2, 0.02, 2, 1000000.0, -1000000.0, ""}
{IOC:, 7, "m$(N)", "asynMotor", XPS1, 6, "size X", mm, Pos, 50., 0, 0.25, 0, 1, .2, 0.0005, 4, 25.0, -25.0, ""}
{IOC:, 8, "m$(N)", "asynMotor", XPS1, 7, "size Y", mm, Pos, 50., 0, 0.25, 0, 1, .2, 0.0005, 4, 25.0, -25.0, ""}
pattern
{P, R, PORT, ADDR}
{IOC:, m6, XPS1, 5}
{IOC:, m7, XPS1 6}
{IOC:, m8, XPS1 7}
Here's the contents of my XPSAux.substitions file:
file "$(MOTOR)/db/XPSAuxLi.db"
pattern
{P, R, PORT, CHAN, SCAN}
{IOC:, XPSAux1Li, XPS_AUX1, 0, "I/O Intr"}
{IOC:, XPSAux2Li, XPS_AUX1, 1, "I/O Intr"}
{IOC:, XPSAux3Li, XPS_AUX1, 2, "I/O Intr"}
{IOC:, XPSAux4Li, XPS_AUX1, 3, "I/O Intr"}
file "$(MOTOR)/db/XPSAuxBi.db"
pattern
{P, R, PORT, CHAN, MASK, SCAN}
{IOC:, XPSAux1Bi0, XPS_AUX1, 0, 0x000001, "I/O Intr"}
{IOC:, XPSAux1Bi1, XPS_AUX1, 0, 0x000002, "I/O Intr"}
{IOC:, XPSAux1Bi2, XPS_AUX1, 0, 0x000004, "I/O Intr"}
{IOC:, XPSAux1Bi3, XPS_AUX1, 0, 0x000008, "I/O Intr"}
{IOC:, XPSAux1Bi4, XPS_AUX1, 0, 0x000010, "I/O Intr"}
{IOC:, XPSAux1Bi5, XPS_AUX1, 0, 0x000020, "I/O Intr"}
{IOC:, XPSAux1Bi6, XPS_AUX1, 0, 0x000040, "I/O Intr"}
{IOC:, XPSAux1Bi7, XPS_AUX1, 0, 0x000080, "I/O Intr"}
{IOC:, XPSAux2Bi0, XPS_AUX1, 1, 0x000001, "I/O Intr"}
{IOC:, XPSAux2Bi1, XPS_AUX1, 1, 0x000002, "I/O Intr"}
{IOC:, XPSAux2Bi2, XPS_AUX1, 1, 0x000004, "I/O Intr"}
{IOC:, XPSAux2Bi3, XPS_AUX1, 1, 0x000008, "I/O Intr"}
{IOC:, XPSAux2Bi4, XPS_AUX1, 1, 0x000010, "I/O Intr"}
{IOC:, XPSAux2Bi5, XPS_AUX1, 1, 0x000020, "I/O Intr"}
{IOC:, XPSAux3Bi0, XPS_AUX1, 2, 0x000001, "I/O Intr"}
{IOC:, XPSAux3Bi1, XPS_AUX1, 2, 0x000002, "I/O Intr"}
{IOC:, XPSAux3Bi2, XPS_AUX1, 2, 0x000004, "I/O Intr"}
{IOC:, XPSAux3Bi3, XPS_AUX1, 2, 0x000008, "I/O Intr"}
{IOC:, XPSAux3Bi4, XPS_AUX1, 2, 0x000010, "I/O Intr"}
{IOC:, XPSAux3Bi5, XPS_AUX1, 2, 0x000020, "I/O Intr"}
{IOC:, XPSAux4Bi0, XPS_AUX1, 3, 0x000001, "I/O Intr"}
{IOC:, XPSAux4Bi1, XPS_AUX1, 3, 0x000002, "I/O Intr"}
{IOC:, XPSAux4Bi2, XPS_AUX1, 3, 0x000004, "I/O Intr"}
{IOC:, XPSAux4Bi3, XPS_AUX1, 3, 0x000008, "I/O Intr"}
{IOC:, XPSAux4Bi4, XPS_AUX1, 3, 0x000010, "I/O Intr"}
{IOC:, XPSAux4Bi5, XPS_AUX1, 3, 0x000020, "I/O Intr"}
{IOC:, XPSAux4Bi6, XPS_AUX1, 3, 0x000040, "I/O Intr"}
{IOC:, XPSAux4Bi7, XPS_AUX1, 3, 0x000080, "I/O Intr"}
{IOC:, XPSAux4Bi8, XPS_AUX1, 3, 0x000100, "I/O Intr"}
{IOC:, XPSAux4Bi9, XPS_AUX1, 3, 0x000200, "I/O Intr"}
{IOC:, XPSAux4Bi10, XPS_AUX1, 3, 0x000400, "I/O Intr"}
{IOC:, XPSAux4Bi11, XPS_AUX1, 3, 0x000800, "I/O Intr"}
{IOC:, XPSAux4Bi12, XPS_AUX1, 3, 0x001000, "I/O Intr"}
{IOC:, XPSAux4Bi13, XPS_AUX1, 3, 0x002000, "I/O Intr"}
{IOC:, XPSAux4Bi14, XPS_AUX1, 3, 0x004000, "I/O Intr"}
{IOC:, XPSAux4Bi15, XPS_AUX1, 3, 0x008000, "I/O Intr"}
file "$(MOTOR)/db/XPSAuxBo.db"
pattern
{P, R, PORT, CHAN, MASK}
{IOC:, XPSAux1Bo0, XPS_AUX1, 0, 0x000001}
{IOC:, XPSAux1Bo1, XPS_AUX1, 0, 0x000002}
{IOC:, XPSAux1Bo2, XPS_AUX1, 0, 0x000004}
{IOC:, XPSAux1Bo3, XPS_AUX1, 0, 0x000008}
{IOC:, XPSAux1Bo4, XPS_AUX1, 0, 0x000010}
{IOC:, XPSAux1Bo5, XPS_AUX1, 0, 0x000020}
{IOC:, XPSAux1Bo6, XPS_AUX1, 0, 0x000040}
{IOC:, XPSAux1Bo7, XPS_AUX1, 0, 0x000080}
{IOC:, XPSAux3Bo0, XPS_AUX1, 1, 0x000001}
{IOC:, XPSAux3Bo1, XPS_AUX1, 1, 0x000002}
{IOC:, XPSAux3Bo2, XPS_AUX1, 1, 0x000004}
{IOC:, XPSAux3Bo3, XPS_AUX1, 1, 0x000008}
{IOC:, XPSAux3Bo4, XPS_AUX1, 1, 0x000010}
{IOC:, XPSAux3Bo5, XPS_AUX1, 1, 0x000020}
{IOC:, XPSAux4Bo0, XPS_AUX1, 2, 0x000001}
{IOC:, XPSAux4Bo1, XPS_AUX1, 2, 0x000002}
{IOC:, XPSAux4Bo2, XPS_AUX1, 2, 0x000004}
{IOC:, XPSAux4Bo3, XPS_AUX1, 2, 0x000008}
{IOC:, XPSAux4Bo4, XPS_AUX1, 2, 0x000010}
{IOC:, XPSAux4Bo5, XPS_AUX1, 2, 0x000020}
{IOC:, XPSAux4Bo6, XPS_AUX1, 2, 0x000040}
{IOC:, XPSAux4Bo7, XPS_AUX1, 2, 0x000080}
{IOC:, XPSAux4Bo8, XPS_AUX1, 2, 0x000100}
{IOC:, XPSAux4Bo9, XPS_AUX1, 2, 0x000200}
{IOC:, XPSAux4Bo10, XPS_AUX1, 2, 0x000400}
{IOC:, XPSAux4Bo11, XPS_AUX1, 2, 0x000800}
{IOC:, XPSAux4Bo12, XPS_AUX1, 2, 0x001000}
{IOC:, XPSAux4Bo13, XPS_AUX1, 2, 0x002000}
{IOC:, XPSAux4Bo14, XPS_AUX1, 2, 0x004000}
{IOC:, XPSAux4Bo15, XPS_AUX1, 2, 0x008000}
file "$(MOTOR)/db/XPSAuxLo.db"
pattern
{P, R, PORT, CHAN}
{IOC:, XPSAux1Lo, XPS_AUX1, 0}
{IOC:, XPSAux3Lo, XPS_AUX1, 1}
{IOC:, XPSAux4Lo, XPS_AUX1, 2}
file "$(MOTOR)/db/XPSAuxAi.db"
pattern
{P, R, PORT, CHAN, LOPR, HOPR, PREC, SCAN}
{IOC:, XPSAuxAi0, XPS_AUX1, 0, -10.0, 10.0, 4, "1 second"}
{IOC:, XPSAuxAi1, XPS_AUX1, 1, -10.0, 10.0, 4, "1 second"}
{IOC:, XPSAuxAi2, XPS_AUX1, 2, -10.0, 10.0, 4, "1 second"}
{IOC:, XPSAuxAi3, XPS_AUX1, 3, -10.0, 10.0, 4, "1 second"}
file "$(MOTOR)/db/XPSAuxAo.db"
pattern
{P, R, PORT, CHAN, DRVL, LOPR, DRVH, HOPR, PREC}
{IOC:, XPSAuxAo0, XPS_AUX1, 0, -10.0, -10.0, 10.0, 10.0, 4}
{IOC:, XPSAuxAo1, XPS_AUX1, 1, -10.0, -10.0, 10.0, 10.0, 4}
{IOC:, XPSAuxAo2, XPS_AUX1, 2, -10.0, -10.0, 10.0, 10.0, 4}
{IOC:, XPSAuxAo3, XPS_AUX1, 3, -10.0, -10.0, 10.0, 10.0 4}
Jesse Hopkins, PhD
Deputy Director
BioCAT, Sector 18
- RE: [Ext] RE: Help with motorNewport config Mark Rivers via Tech-talk
- Help with motorNewport config Jesse Hopkins via Tech-talk
- RE: Help with motorNewport config Mark Rivers via Tech-talk
- Re: [Ext] RE: Help with motorNewport config Jesse Hopkins via Tech-talk
RE: Very stange compile error on Windows Mark Rivers via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
