1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: RE: Windows path syntax problem
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "freddie.akeroyd at stfc.ac.uk" <freddie.akeroyd at stfc.ac.uk>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 28 Nov 2024 21:33:46 +0000
I solved the problem.  It had nothing to do with the EPICS build system.  I commented out all references to the dcamapi library and its path in my Makefiles, but I still got this error:
LINK : fatal error LNK1104: cannot open file '../../../lib/win64/dcamapi.lib'
I figured out that the problem was that one of the vendor’s include files, console4.h, contained these lines:
#if defined(_WIN64)
#pragma comment(lib,"../../../lib/win64/dcamapi.lib")
#elif defined(WIN32)
#pragma comment(lib,"../../../lib/win32/dcamapi.lib")
That is why it was looking for the file in that path.  I commented out those lines, and then it builds fine.
Sent: Thursday, November 28, 2024 12:54 PM
To: freddie.akeroyd at stfc.ac.uk; tech-talk at aps.anl.gov
Subject: Windows path syntax problem
Folks,
I am having problems with the “lib_DIR” syntax on Windows.  It works fine on Linux.
My application Makefile contains these lines:
PROD_LIBS += hamamatsu
ifeq ($(OS_CLASS), Linux)
  PROD_LIBS += dcamapi
  dcamapi_DIR = /usr/local/lib
endif
ifeq ($(OS_CLASS), WIN32)
  dcamapi_DIR = C:/Hamamatsu/dcamsdk4/lib/win64
endif
When I build the application on Linux I get this output. .  I have edited the output add newlines, removed irrelevant directories, and highlighted the path to libdcamapi.so.
/usr/bin/g++ -o hamamatsuApp
-L/corvette/home/epics/devel/areaDetector-3-13/ADHamamatsuDCAM/lib/linux-x86_64
-L/corvette/home/epics/devel/areaDetector-3-13/ADHamamatsuDCAM/iocs/hamamatsuIOC/lib/linux-x86_64
-L/corvette/home/epics/devel/areaDetector-3-13/ADCore/lib/linux-x86_64
-L/corvette/usr/local/epics-devel/base-7.0.8/lib/linux-x86_64
-L/usr/local/lib
-Wl,-rpath,/corvette/home/epics/devel/areaDetector-3-13/ADHamamatsuDCAM/lib/linux-x86_64
-Wl,-rpath,/corvette/home/epics/devel/areaDetector-3-13/ADHamamatsuDCAM/iocs/hamamatsuIOC/lib/linux-x86_64
-Wl,-rpath,/corvette/home/epics/devel/areaDetector-3-13/ADCore/lib/linux-x86_64
-Wl,-rpath,/corvette/usr/local/epics-devel/base-7.0.8/lib/linux-x86_64
-Wl,-rpath,/usr/local/lib
-rdynamic -m64
hamamatsuApp_registerRecordDeviceDriver.o hamamatsuAppMain.o
-lhamamatsu
-ldcamapi
-lNDPlugin
-ldbCore -lca -lCom  -lboost_system -lX11 -lXext
Installing created executable ../../../bin/linux-x86_64/hamamatsuApp
It correctly adds /usr/local/lib to the linking path, and finds libdcamapi.so.
On Windows that library is in this location:
C:\Hamamatsu\dcamsdk4\lib\win64\dcamapi.lib
If I run the “dir” command on that path I see the file:
hamamatsuApp\src>dir C:\Hamamatsu\dcamsdk4\lib\win64\dcamapi.lib
Volume in drive C has no label.
Volume Serial Number is 6E2E-56EE
Directory of C:\Hamamatsu\dcamsdk4\lib\win64
08/27/2024  06:51 AM            24,984 dcamapi.lib
               1 File(s)         24,984 bytes
               0 Dir(s)  424,390,684,672 bytes free
When I run make I get this error.  I have edited the output add newlines and removed irrelevant directories:
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:hamamatsuApp.exe
hamamatsuApp_registerRecordDeviceDriver.obj hamamatsuAppMain.obj
../../../../../lib/windows-x64-static/hamamatsu.lib
C:/Hamamatsu/dcamsdk4/lib/win64/dcamapi.lib
J:/epics/devel/areaDetector-3-13/ADCore/lib/windows-x64-static/NDPlugin.lib
J:/epics/devel/areaDetector-3-13/ADCore/lib/windows-x64-static/ADBase.lib
H:/epics-devel/base-7.0.8/lib/windows-x64-static/ca.lib
H:/epics-devel/base-7.0.8/lib/windows-x64-static/Com.lib
netapi32.lib gdi32.lib oleaut32.lib psapi.lib ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib dbghelp.lib
make[1]: *** [H:/epics-devel/base-7.0.8/configure/RULES_BUILD:231: hamamatsuApp.exe] Error 1104
The boldface line is the correct path to the vendor library, using the forward slash separators. But the linker is not finding the file.  It is using the correct end of the path, lib/win64/dcamapi.lib, but not the start of the path.
I don’t understand this.  It seems like the link command is being passed the correct path, but the linker is not finding the file?
Windows path syntax problem Mark Rivers via Tech-talk
Prev: Windows path syntax problem Mark Rivers via Tech-talk
Next: Re: Re: RE: [SPAM] Re: autoConnect could not connect when reading a register by modbus relative addressing Zhibang Shen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: Event record John Dobbins via Tech-talk
ANJ, 29 Nov 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
