1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: medm edit mode SIGSEGV core dump Ubuntu 24.04.
From: "Soliday, Robert T. via Tech-talk" <[email protected]>
To: "Muir, John Lewis" <[email protected]>
Date: Mon, 9 Dec 2024 16:34:05 +0000
True, but I don't know why the delay helps and don't have a lot of spare time to work on something that only affects the edit mode of MEDM. If someone wants to suggest a proper fix, then I am willing to test it and update the official release. Maybe over the holiday break I can look into this further.
--Bob
Sent: Monday, December 9, 2024 10:10 AM
To: Soliday, Robert T. <[email protected]>
Cc: [email protected] <[email protected]>; Huang, Rong <[email protected]>
On 12/06, Soliday, Robert T. via Tech-talk wrote: > I was able to duplicate the problem with MEDM in edit mode on Ubuntu 24. 04 and verified that your source code change is an effective workaround. I have updated our Github release to include
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
> I was able to duplicate the problem with MEDM in edit mode on Ubuntu 24.04 and verified that your source code change is an effective workaround. I have updated our Github release to include this fix.
Wouldn't it be better to actually understand the problem instead of
committing workarounds that add delays?  I think this should have a
source code comment saying why the delay is there.  Also, the commit
message has no indication of why the delay is needed.
Lewis
medm edit mode SIGSEGV core dump Ubuntu 24.04. Rong Huang via Tech-talk
Re: medm edit mode SIGSEGV core dump Ubuntu 24.04. Soliday, Robert T. via Tech-talk
Re: medm edit mode SIGSEGV core dump Ubuntu 24.04. J. Lewis Muir via Tech-talk
Prev: Re: medm edit mode SIGSEGV core dump Ubuntu 24.04. J. Lewis Muir via Tech-talk
Next: Re: Aerotech Automation1 motor questions Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Java Status? Kim Gillies via Tech-talk
