1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Using Aerotech Automation1 motor controller with EPICS - controller initialization
From: John Dobbins via Tech-talk <[email protected]>
Cc: Seth Bywater <[email protected]>, "Eric J. Edwards" <[email protected]>
Date: Thu, 2 Jan 2025 18:52:34 +0000
All,
I am working on integrating an Aerotech Automation1 Motor Controller into operations at CHESS.
We are using an EPICS IOC as a layer between the motor controller and SPEC, the software beamline scientists use to control experiment data acquisition.  The IOC appears to work, i.e. we can enable/disable the motor, home the motor,  and command moves through EPICS.
I am wondering about what is required for controller initialization.
The Automation1 controllers are new to us, but my understanding is that when one connects Automation1 Studio to the controller, the controller is configured using an associated .mcd file.
In my tests to date I believe the controller has already been configured by Automation1 Studio before I start the IOC.   I am wondering if this is a requirement, i.e. if the controller is for example power cycled, does it need to be configured via Autmation1 Studio before it is usable by the EPICS IOC.
The EPICS IOC does some initialization of the controller, e.g. setting velocity, but I don't know if and doubt that this initialization is complete.
Also, more generally, if the motor controller is initialized via Automation Studio and the controller is power cycled, what state does the motor controller come up in?  Are the settings non-volatile? Or does the controller come up in a 'blank' state?
Regards and Happy 2025,
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Re: Using Aerotech Automation1 motor controller with EPICS - controller initialization Mark Rivers via Tech-talk
Re: Using Aerotech Automation1 motor controller with EPICS - controller initialization Peterson, Kevin M. via Tech-talk
Prev: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
Next: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: I implemented the Model 3 of EPICS motor driver support, but the VAL and RBV of motor record are zero after IOC reboot. Torsten Bögershausen via Tech-talk
Next: Re: Using Aerotech Automation1 motor controller with EPICS - controller initialization Mark Rivers via Tech-talk
