1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: MRF kernel modules not seeing hardware
From: "Daykin, Evan via Tech-talk" <[email protected]>
To: "Shen, Guobao" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Jan 2025 20:54:58 +0000
Hi Guobao,
Thanks for your reply. System.map is present in /boot as System.map-$(uname -r). I just re-tried where depmod failed by running `depmod -a -F /boot/$(uname -r)` [1]. It again seems to have installed and loaded the module (at least according to lsmod and dmesg), but the devices themselves are still not appearing. I’ll try again with -F -e, see if anything’s missing and report back.
[1] https://linux.die.net/man/8/depmod
Sent: Wednesday, January 29, 2025 3:47 PM
To: Daykin, Evan <[email protected]>; [email protected]
Subject: Re: MRF kernel modules not seeing hardware
[EXTERNAL] This email originated from outside of FRIB
Even,
Looks like you are missing the “System.map” file, as your message hinted.
ChatGPT gives some suggestions as below:
It looks like you're encountering an issue where the `System.map` file is missing during the kernel module installation. The `System.map` file is a key component for kernel debugging and the `depmod` utility, which is responsible for managing module dependencies, relies on it to create the necessary module dependency files.
Here’s a breakdown of what's going on and how to fix it:
### What’s Happening?
- **Warning**: The kernel installation process is not able to find the `System.map` file. This file typically resides in the `/boot/` directory and contains a map of kernel symbols (i.e., the addresses of kernel functions and variables). Without it, `depmod` cannot properly process the modules.
### Steps to Resolve:
1. **Verify if `System.map` exists**:
   Check if the `System.map` file exists in the `/boot/` directory for your kernel version. You can use:
   ```bash
   ls /boot | grep System.map
   It should show something like `System.map-6.1.0-30-rt-amd64`. If it doesn’t appear, it could mean that the file wasn’t generated during the kernel installation.
2. **Rebuild the `System.map` file**:
   If the file is missing, you can rebuild it using `make` from the kernel source directory, assuming you have the kernel source for `6.1.0-30-rt-amd64` installed. To do this:
   - Navigate to the directory where the kernel source is located.
   - Run the following:
     ```bash
     make modules_prepare
     This command prepares the kernel source tree for module compilation and will also regenerate the `System.map` file.
3. **Reinstall or Rebuild the Kernel**:
   In some cases, reinstalling or rebuilding the kernel might regenerate the necessary files. You can reinstall the kernel package or rebuild it using the package manager, for example, with `apt` on Debian-based systems:
   ```bash
   sudo apt-get install --reinstall linux-image-6.1.0-30-rt-amd64
4. **Manually Generate the `System.map`**:
   If you have the kernel binary (`vmlinuz-6.1.0-30-rt-amd64`), you can manually generate the `System.map` using the following:
   ```bash
   nm /boot/vmlinuz-6.1.0-30-rt-amd64 > /boot/System.map-6.1.0-30-rt-amd64
   This will create the `System.map` file based on the symbols in the kernel image.
5. **Run `depmod` Manually**:
   After fixing the missing `System.map` file, you may want to run `depmod` manually to rebuild the module dependencies:
   ```bash
   sudo depmod -a
6. **Check Kernel Headers**:
   Ensure the kernel headers are installed, as these are required for building modules:
   ```bash
   sudo apt-get install linux-headers-$(uname -r)
### Final Check:
Once you’ve taken these steps, check again if the warning goes away. You should now be able to install the PCI kernel module without issues.
Let me know if this helps or if you're seeing any other errors!
From: Tech-talk <[email protected]> on behalf of Daykin, Evan via Tech-talk <[email protected]>
Date: Wednesday, January 29, 2025 at 9:17
AM
To: [email protected] <[email protected]>
Subject: MRF kernel modules not seeing hardware
Hello,
On a new linux kernel 6.1.0-30-rt-amd64 installation, I am trying to install the mrfioc2 PCI kernel module by running the following:
sudo make KERNELDIR=/lib/modules/$(uname -r)/build modules_install
make -C /lib/modules/6.1.0-30-rt-amd64/build DRV_VERSION='3' M=/home/daykin/git/mrfioc2/mrmShared/linux modules_install
make[1]: Entering directory '/usr/src/linux-headers-6.1.0-30-rt-amd64'
  INSTALL /lib/modules/6.1.0-30-rt-amd64/extra/mrf.ko
  DEPMOD  /lib/modules/6.1.0-30-rt-amd64
Warning: modules_install: missing 'System.map' file. Skipping depmod.
make[1]: Leaving directory '/usr/src/linux-headers-6.1.0-30-rt-amd64'
depmod -a && modprobe: <no output>
lsmod|grep mrf
mrf                    24576  0
uio                    28672  1 mrf
parport                73728  1 mrf
cat /proc/devices
Character devices:
  1 mem
  4 /dev/vc/0
  4 tty
  4 ttyS
  5 /dev/tty
  5 /dev/console
  5 /dev/ptmx
  7 vcs
10 misc
13 input
29 fb
116 alsa
128 ptm
136 pts
153 spi
180 usb
189 usb_device
226 drm
238 uio
239 aux
240 cec
241 lirc
242 ipmidev
243 watchdog
244 mei
245 nvme-generic
246 nvme
247 cxl
248 bsg
249 ptp
250 pps
251 rtc
252 dax
253 tpm
254 gpiochip
Block devices:
  7 loop
254 device-mapper
259 blkext
sudo dmesg|grep mrf
[  508.671574] mrf: loading out-of-tree module taints kernel.
[  508.671603] mrf: module verification failed: signature and/or required key missing - tainting kernel
I have also tried uninstalling the mrfioc2 version and installing Jukka’s driver (https://github.com/jpietari/mrf-linux-driver) after some small modifications for the deprecation of HAS_UNLOCKED_IOCTL and ioremap_nocache, the module builds successfully but the module_load script also indicates it doesn’t see any EVGs/EVRs.
In both cases, the device files /dev/uio* or /dev/era* are not installed, and the output of lspci is as follows:
sudo lspci -vv -nn -s 07:0f.0
07:0f.0 Signal processing controller [1180]: Micro-Research Finland Oy Device [1a3e:150c] (rev 01)
     Subsystem: Micro-Research Finland Oy Device [1a3e:150c]
     Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
     Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=slow >TAbort+ <TAbort- <MAbort- >SERR- <PERR- INTx-
     Interrupt: pin A routed to IRQ 255
     IOMMU group: 15
     Region 0: Memory at a1000000 (32-bit, non-prefetchable) [disabled] [size=1M]
     Capabilities: [40] Null
sudo lspci -vv -nn -s 07:0e.0
07:0e.0 Signal processing controller [1180]: Micro-Research Finland Oy Device [1a3e:250c] (rev 01)
     Subsystem: Micro-Research Finland Oy Device [1a3e:250c]
     IOMMU group: 15
     Region 0: Memory at a1100000 (32-bit, non-prefetchable) [disabled] [size=1M]
I’ve tried with multiple cards, including some known to be working on older installations and hardware. Is there something I’m missing?
Evan
MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
Re: MRF kernel modules not seeing hardware Shen, Guobao via Tech-talk
Prev: Re: MRF kernel modules not seeing hardware Shen, Guobao via Tech-talk
Next: Re: MRF kernel modules not seeing hardware Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
