1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: MRF kernel modules not seeing hardware
To: Di Wang <[email protected]>
Cc: EPICS tech-talk <[email protected]>, [email protected], [email protected]
Date: Wed, 29 Jan 2025 18:52:54 -0800
Hi Di,
On Wed, Jan 29, 2025 at 5:55 PM Di Wang <[email protected]> wrote:
Hi Evan,
> I can't create a /dev node via udev or otherwise. The bizarre thing is that when I replace the problem CPU card/installation with a known "working" installation, the device ids are the typical,  supported "Signal processing controller: Device 1a3e:152c/252c, everything corresponding to your pciids repo.
According to this information, it seems that the PCI ID is not correct.
The PCI ID for your cPCI EVG/EVR 300 (0x250c/0x150c) are wrong. Correct
value should be 0x252c/0x152c. Perhaps a bit-reversal occurred?
I also encountered similar problem several years before when I failed to
use one of my PXI EVR. Later I found that its PCI ID (0x10e6) was
wrongly set to a PMC EVR's (0x11e6).
I suggest you to first re-flash the firmware and verify this error is
caused by MRF firmware or CPU card.
You can download firmware here or contact Jukka.
https://github.com/jpietari/mrf-firmware/tree/main/dc
FYI, The supported PCI IDs
https://github.com/epics-modules/mrfioc2/blob/master/mrmShared/linux/uio_mrf.c#L41-L74
Thank you for that information, I will update the pciids (my own repo) to use the latest information.
Best,
Han
Cheers
Di Wang
KEK
Jeong Han Lee, Dr.rer.nat.
Lawrence Berkeley National Laboratory
Re: MRF kernel modules not seeing hardware Michael Davidsaver via Tech-talk
Prev: Re: MRF kernel modules not seeing hardware Di Wang via Tech-talk
Next: Re: MRF kernel modules not seeing hardware Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
