1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: archiver appliance and CA -> PVA
Date: Thu, 30 Jan 2025 15:10:27 +0000
Hi all,
Furthermore, even explicity archiving them with
pva:// they still won't
connect.  Apart from reverting back to CA, what can I do so that they
connect to the AA with PVA?
Resubmitting should work, but the PVs need to be removed from the archiver first, via delete for example. We currently don’t have a feature to migrate from CA to PVA or vice versa. Sounds like a good idea though, made an issue:
https://github.com/archiver-appliance/epicsarchiverap/issues/325
For fun, I tried simply changing this key for a couple of
scalar double PVs.  I was a little concerned that these
might show up as Type Change events, which AA does not
handle.  However, in this case it did not.  So all is well.
This I think should work, but probably you want to do a restart of the archiver after rather than doing this live.
An alternative is:
Pause the pv
Use the /getPVTypeInfo endpoint to get the type info
Edit the json output to have pvAccess set to True
Use the /putPVTypeInfo endpoint https://epicsarchiver.readthedocs.io/en/latest/developer/mgmt_scriptables.html to update the pvTypeInfo.
Resume the PV
I don’t particularly want to encourage this , as it isn’t much different to manually changing in the db. And just as risky. Resubmission I think is the safest method.
Hope that helps
Sky
Prev: Re: MRF kernel modules not seeing hardware Jukka Pietarinen via Tech-talk
Next: RE: MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: archiver appliance and CA -> PVA Pierrick M Hanlet via Tech-talk
Next: Understanding ASYN_CANBLOCK Marco Filho via Tech-talk
