1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Forking EPICS processes
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Grzegorz Kowalski <[email protected]>
Cc: [email protected]
Date: Tue, 4 Feb 2025 11:00:34 -0800
On 2/4/25 05:24, Grzegorz Kowalski via Tech-talk wrote:
Hello,
I'm working on a multiprocess application using EPICS.
My main process only reads the configuration and spins up child processes where EPICS is actually used.
However, when forking I get this warning:
Warning: Undefined Behavior!
          Detected use of epicsThread from child process after fork()
Is there a way to avoid starting any epicsThreads in the main process and only do so in a child process that needs them?
To answer this, we would have to know more about your application.
Which of the Base libraries you are loading, and how.  What calls
are made...
If your code is linked as a single executable, I would suggest loading
that executable in GDB add setting a break point for epicsThreadInit()
to see how it is called.
for reference:
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/211__;!!G_uCfscf7eWS!bgAMhJAZ5CmlyLqDgEKwh4Qx7DDYbD_sG0F7J2uxlHJIvbJVbDD4dU4t-Oc9HgqpFZ10C66zKCweiBEs0DLH8R_aJQ$
Re: Forking EPICS processes Grzegorz Kowalski via Tech-talk
Prev: Forking EPICS processes Grzegorz Kowalski via Tech-talk
Next: PVA Gateway issues with two networks client Saisrikiran Mudigonda via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Forking EPICS processes Grzegorz Kowalski via Tech-talk
