1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Installation of EPICS archiver on a single Centos7 machin
From: Andrea Celentano via Tech-talk <[email protected]>
To: "Shankar, Murali" <[email protected]>
Date: Fri, 7 Feb 2025 19:28:08 +0100
Dear Shankar,
thanks for your reply. Indeed, for the moment I solved by using the previous version, and it seems to work now.
Cheers,
Andrea
On Feb 7, 2025, at 17:41, Shankar, Murali via Tech-talk <[email protected]> wrote:
2.0.5 has this issue where the archappl.properties file is missing in the default build. You can use the one for the tests site as your starting point
Murali
Re: Installation of EPICS archiver on a single Centos7 machin Shankar, Murali via Tech-talk
Prev: Re: Installation of EPICS archiver on a single Centos7 machin Shankar, Murali via Tech-talk
Next: RE: MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Archive Viewer John Dobbins via Tech-talk
