1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Archiver Appliance - Limit on PVs
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Thu, 13 Feb 2025 18:38:14 +0000
Re: 4 Tomcats with 2GB for each one.
I would give the engine as much memory as possible. For example, we use something like -Xms6G -Xmx24G
Re: archappl_install/engine/logs/catalina.out
In general, logging is controlled with log4j2 configuration in tomcat/lib/log4j2.xml. But this does not control catalina.out which is the stdout of the tomcat process. You need to figure out what's logging so much there and maybe control it using Tomcat configuration. For reference, my engine/logs/catalina.out is 0 bytes.
Hope that helps.
Murali
Prev: IOC, QServ, and AMSG / alarm.message Ivan Finch - STFC UKRI via Tech-talk
Next: Re: IOC, QServ, and AMSG / alarm.message Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Archiver Appliance - Limit on PVs Eusebio Naif Al-Soliman Fuentes via Tech-talk
Next: MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
