1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: IOC, QServ, and AMSG / alarm.message
From: Aqeel Alshafei - STFC UKRI via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Fri, 14 Feb 2025 15:53:08 +0000
Hello Michael,
the alarm.message is not set based on AMSG field. alarm.message string value set to "STATE" then alarm is Minor or Major.
AMSG was set only when the record/PV is in the invalid state. I also tried NMSG field, it behave the same as AMSG, except  when PV is invalid is set the alarm.message to "UDF"
so, alarm.message is set when alarm.severity = 3 AND alarm.status = 2. Otherwise, it does not use the AMSG field and set the string value "STATE"
the database below should be able to reproduce what I am encountering. a quick way to make the bi record invalid is to set proc to true instead of "CP" then the alarm.message would be set.
record(calcout, "$(P):$(R):CALC") {
    field(INPA, "0x101")
    field(CALC, "A")
    field(SCAN, "1 second")
record (mbbiDirect, "$(P):$(R):SIMULATED") {
    field("DESC", "mbbiDirect from calcout")
    field(INP,{pva:{pv:"$(P):$(R):CALC", proc:"CP"}})
record(bi, "$(P):$(R):SIMULATED:B0") {
    field(INP, {pva:{pv:"$(P):$(R):SIMULATED.B0", proc:"CP"}})
    field(ZNAM, "OFF")
    field(ONAM, "ON")
    field(OSV, "MAJOR")
    field(NAMSG, "I AM IN AN ALARM STATE")
Best Regards
Aqeel AlShafei
ISIS Controls
From: Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
Sent: 13 February 2025 21:53
To: Finch, Ivan (STFC,RAL,ISIS) <[email protected]>
Cc: [email protected] <[email protected]>
Hi Ivan,
On 2/13/25 08:21, Ivan Finch - STFC UKRI via Tech-talk wrote:
> Hello,
> We have setup a simple IOC with bi records triggered by forward links such as the following:
What you are trying to do should work.
Can you test with: https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/100__;!!G_uCfscf7eWS!Z6EvnRv0uZpu2-5tpfa-eWbruUmdHDvYFuD2e3Hqz8btrWMPr7Mbd5da1kY-Kh2iqsPVIsllxL7xenGFhtxHi3Xfqg$  ?
> We’ve investigated setting the AMSG and NAMSG fields in the record, but suspect that this is intended to be set programmatically?
The idea is for device support to change to recGblSetSevrMsg()
in places where recGblSetSevr() is used to signal an alarm.
> int recGblSetSevrMsg(void *precord,
>                      epicsEnum16 new_stat,
>                      epicsEnum16 new_sevr,
>                      const char *msg, ...)
So printf() format strings can be used, although there is a
limit of 40 characters (aka. DB_AMSG_SIZE).
> Thank you in advance for any assistance you can provide,
> Ivan Finch
> ISIS Controls
Re: IOC, QServ, and AMSG / alarm.message Michael Davidsaver via Tech-talk
IOC, QServ, and AMSG / alarm.message Ivan Finch - STFC UKRI via Tech-talk
Prev: Re: IOC, QServ, and AMSG / alarm.message Michael Davidsaver via Tech-talk
Next: StreamDevice Checksum formatting bug Baily, Scott A via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Re: IOC, QServ, and AMSG / alarm.message Michael Davidsaver via Tech-talk
