1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: RE: Make waveform from ai record
From: Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov>
To: Žiga Oven <ziga.oven at cosylab.com>, "tech-talk at aps.anl.gov" <Tech-talk at aps.anl.gov>
Date: Mon, 24 Feb 2025 07:49:26 +0000
Hello Ziga
Thanks, this is working as I expected by setting the waveform scan to 1 second. This maybe a general question not related only to my case, but how to conditionally trigger a PV from within EPICS records? I just had an idea where I want to export or scan the waveform once I had 200 samples exactly, already in the IOC I am tracking the number of samples.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
Email : abdalla.ahmad at sesame.org.jo
Website: www.sesame.org.jo
Sent: Thursday, February 20, 2025 10:37 AM
To: Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo>; tech-talk at aps.anl.gov
Hi Abdalla,
One way how to create waveform from scalars with EPICS records is Compress Record with an ALG field set to Circular Buffer and INP field pointing to your AI record.
https://epics.anl.gov/base/R7-0/8-docs/compressRecord.html
You still have to configure processing of the compress record (either FLNK from AI record, or CP flag on the INP link) to capture all the 200 samples.
Then you can point a waveform record to read the 200 sample with either 1 second SCAN rate or you can create some other (“complex”) logic to extract the data into waveform only when 200 “fresh” samples are in the compress record.
Hope this helps,
Žiga
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Thursday, February 20, 2025 07:56
To: tech-talk at aps.anl.gov
Subject: Make waveform from ai record
Hi
I have a fast ai record (200 Hz) in a stream-device-based IOC. Is there a "standard way" within EPICS records to transform these 200 samples into a single waveform record of size 200 processed at 1 second for example? Thanks.
Best Regards,
Abdalla.
Control Engineer
SESAME
Re: Make waveform from ai record Ralph Lange via Tech-talk
Make waveform from ai record Abdalla Ahmad via Tech-talk
RE: Make waveform from ai record Žiga Oven via Tech-talk
Prev: Re: [EXTERNAL] History of EPICS Foster, Andrew (Observatory Science, RAL, TEC) via Tech-talk
Next: Re: Make waveform from ai record Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: RE: Make waveform from ai record Žiga Oven via Tech-talk
ANJ, 24 Feb 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
