1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: Using Streamdevice to run SQL Query ?
From: Zimoch Dirk via Tech-talk <tech-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 25 Mar 2025 11:03:48 +0000
Hello Heinz,
Does your sql database have a TCP socket to write the queries to? Maybe a web interface?
If not, can you use for example ncat to pass queries from a TCP socket to stdin of a sql command line interface?
Once you have a TCP port that accepts sql queries, it should be possible to use it with StreamDevice.
Dirk
> On 25 Mar 2025, at 07:24, Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Good morning,
> We are currently having an EPICS training week. A participant asked if it is possible
> to create PVs that can make an SQL query against a mySQL database.
> The measurement data is stored by a foreign system in a database.
> The idea is to provide the values in the database as EPICS-PVs for caput/caget.
> Has anyone done this before?
> Thanks Heinz
RE: Using Streamdevice to run SQL Query ? Freddie Akeroyd - STFC UKRI via Tech-talk
Using Streamdevice to run SQL Query ? Heinz Junkes via Tech-talk
Prev: Using Streamdevice to run SQL Query ? Heinz Junkes via Tech-talk
Next: RE: Using Streamdevice to run SQL Query ? Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
ANJ, 25 Mar 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
