1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Stream2 support in ADEiger
From: "Yendell, Gary \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 3 Apr 2025 14:38:37 +0000
Hi Mark,
We started trying to integrate this at DLS when Dectris were developing stream2 and asking for feedback. It didn't quite make it to production and has since been sitting idle as its not a priority for us right now, but the implementation would probably be a good starting point for implementing it in ADEiger.
The key thing you are going to want to do is make use of the stream2 C library dectris have written to parse the cbor buffers from the detector, along with tinycbor. This is available here
we included it in our build by adding that repo as a submodule in the third_party directory here:
this will save a ton of effort because parsing cbor in C is very involved.
It is built into the eiger processor plugin here:
Specifically, the handle_rx_socket and handle_*_message functions is where we are using that library to parse the cbor buffer and access the fields:
This implementation was pretty close to what we needed. There is some subtlety left to figure out, for example the start/stop time fields which are an array of time and base frequency that we don't handle properly.
I hope this is useful!
Cheers,
Gary
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 02 April 2025 20:54
To: [email protected] <[email protected]>
Subject: Stream2 support in ADEiger
Folks,
ADEiger needs to have support for the Stream2 interface that Dectris added in firmware 2022.1.
Does anyone know if some site has worked on this?  There are no pull-requests for it in ADEiger on Github.
If not, I plan to work on it soon.
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Stream2 support in ADEiger Mark Rivers via Tech-talk
Prev: Re: RFC: add a mechanism to call epicsExit when signals are received Jure Varlec via Tech-talk
Next: Phoebus is unable to see PVs inside docker containers Srinivas, Dhruv via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Stream2 support in ADEiger Mark Rivers via Tech-talk
Next: RFC: add a mechanism to call epicsExit when signals are received Érico Nogueira Rolim via Tech-talk
