1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: RFC: add a mechanism to call epicsExit when signals are received
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Jure Varlec <[email protected]>
Cc: [email protected]
Date: Fri, 4 Apr 2025 02:32:54 +0100
On 4/3/25 06:17, Jure Varlec via Tech-talk wrote:
On 4/3/25 11:34, Michael Davidsaver via Tech-talk wrote:
wrt. your attached epicsSignalExit.cpp, the method epicsSignalExit::getInstance()
is not async safe since (depending on c++ version) it will run the class
epicsSignalExit constructor.
To be clear, I like the idea that eg. systemd+procServ could
trigger a clean exit.  I just had a past bad experience with
a library unconditionally installing/replacing signal handlers.
fyi. have a look at epicsSignal.h for the limited management
currently possible with libCom.
I don't think that's the case. The signal handler is run only if it is first registered using epicsExitOnSignal(), presumably from iocsh. getInstance() is first used there, which constructs the static object. The next invocation of getInstance() (from the signal handler) will not run the contructor.
True, my mistake.
If this feels icky to you, there might be another approach. Have a global bool specifying whether this feature is enabled or not. The iocsh command then only sets this flag. Thread creation and handler registration is done at IOC init, if the flag is set.
The existing global constructors/destructors in libCom occasionally
cause problems, and I would like to see them removed.  So imo. adding
another seems counterproductive.
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/286__;!!G_uCfscf7eWS!dYXoRGfIz5VngL5KqDx1QwaTsAFBAWPpH_F7hMKcSH79eGAQ_GCLu55dr24IbJSnowSV9Dy2t5qHzRBIb0eGROOuVQ$
I suppose it might also be acceptable to install and remove
a handler with initHook callbacks.
Érico, I don't have the time right now to look deeper into this, but I would love to see something like this because it would make managing IOCs via Systemd more straightforward, not to mention making compulsive use of C-c to terminate IOCs nicer. Thanks for pushing this forward!
For reference, compulsive use of ctrl+d has this effect today.
(closing stdin triggers a return from "iocsh(NULL)" )
It might be fun to teach procServ to try this before signaling.
Also, I recall that the linux-specific "prctl(PR_SET_PDEATHSIG, ...)"
has be used to build cleanup on exit mechanisms which work even
for abnormal termination.
Re: RFC: add a mechanism to call epicsExit when signals are received Érico Nogueira Rolim via Tech-talk
Re: RFC: add a mechanism to call epicsExit when signals are received Michael Davidsaver via Tech-talk
Re: RFC: add a mechanism to call epicsExit when signals are received Jure Varlec via Tech-talk
Prev: Phoebus is unable to see PVs inside docker containers Srinivas, Dhruv via Tech-talk
Next: Re: Phoebus is unable to see PVs inside docker containers Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: RFC: add a mechanism to call epicsExit when signals are received Jure Varlec via Tech-talk
Next: Re: RFC: add a mechanism to call epicsExit when signals are received Érico Nogueira Rolim via Tech-talk
