Thanks for all the advice everyone, I was able to get it working thanks to it. What ended up working for me was setting the addr_list to localhost in the settings.ini file as well as adding the script in the
following link to /etc/network/if-up.d and /etc/network/if-down.d
https://docs.epics-controls.org/en/latest/sys-admin/channel-access-reach-multiple-soft-iocs-linux.html
Also, thank you for the nuanced explanation of why only the first IOC would connect. That explanation fits perfectly with the issues I was seeing, and it’ll help me debug it in the future.
I thought I'd follow up by remarking that running multiple IOCs in host network containers has one small nuance.
carepeater is started inside the first container that launches. The others don't launch it because the carepeater port on the host is already taken.
If you then stop that first IOC, you will take down the carepeater and will have none until the next IOC is started.
Most of the time this is not an issue but it can be an explanation for unexpected behaviour with respect to clients retrying connections to PVs.
When you are using network host, your IOCs should behave exactly as if they were running bare metal from a networking perspective. Therefore phoebus should be able to see them with default configuration. This is
how we run our IOCs in Kubernetes at DLS and we can see PVA and CA for all of them using UDP broadcast from anywhere in the same subnet.
The symptoms you describe sound like you are using UDP unicast to your server running docker. I.e. You have its address in EPICS_CA_ADDR_LIST. This will always see the first IOC only. You need to have EPICS_CA_ADDR_LIST
unset (and EPICS_CA_AUTO_ADDR_LIST unset or "Y") in order to use broadcast and therefore see all IOCs. If your client is not on the same subnet as your IOCs then this won't work and you will need a CA Gateway.
One other thing to check: I know that host network for docker rootless mode was completely broken last time I tried. I'm guessing that you are using docker in it's default rootful mode but thought it was worth
checking that.
If you end up needing a gateway then the main branch of the linked repo demonstrates how to do that too with on CA gateway (and a pvagw) forwarding CA (PVA) into the container network.
Hello Dhruv,
how is your org.phoebus.pv.ca/addr_list formated? It should be a list of IP's seperated by spaces. The observation you have
points to a problem here as it looks like your phoebus sees probably only the first host on that list.
You can check the settings that phoebus sees if you go "Help -> Abaut -> Show Details -> Preference Settings"
You could try to set EPICS_CAS_INTF_ADDR_LIST to be the address of the docker network interface before starting phoebus.
You need to kill caRepeater on the host before starting Poebus. Otherwise the change will not have any effect.
If that does not help, probably the easisest way to go is to implement a gateway on the Docker host.
Hope this helps,
Jörn
Am Donnerstag, 3. April 2025, 19:51:20 Mitteleuropäische Sommerzeit schrieb Srinivas, Dhruv via Tech-talk:
> Hello,
> I'm installing several IOCs on a new machine. If I run it locally on the machine itself, then Phoebus is able to see the PVs in said IOCs. However, when I place the IOCs into a docker image then run it using the following command, Phoebus can only see one
IOC at a time:
> "docker run -dit --network=host --name=<name> <image_name>"
> So far I've attempted to set auto_addr_list, addr_list, and name_servers in the Phoebus settings.ini file. So far I've been able to confirm that my setting changes did take effect, but the problem persists.
> Does anyone happen to know how to resolve this issue?
> Sincerely,
> Dhruv Srinivas
> [email protected]<mailto:[email protected]>
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please
notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source
Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Ltd.
- Re: Phoebus is unable to see PVs inside docker containers Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
- Phoebus is unable to see PVs inside docker containers Srinivas, Dhruv via Tech-talk
- Re: Phoebus is unable to see PVs inside docker containers Jörn Dreyer via Tech-talk
Re: RFC: add a mechanism to call epicsExit when signals are received Érico Nogueira Rolim via Tech-talk
<2025>
2026
<2025>
2026
