1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Phoebus Alarm Server
From: liuxiaomin--- via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Tue, 8 Apr 2025 11:14:13 +0800
I am encountering a critical issue with PV connectivity while using the Phoebus Alarm Server alongside a local EPICS IOC. Both the EPICS IOC and phoebus run on the local device.
EPICS IOC Verification:
Target PV: TEST:CAT1/test:ai1
EPICS_CA_SERVER_PORT=6310
The IOC can run normally and obtain the PV value.
I set the parameters in the setting.ini in alarm-server as follows:
In alarm-server/settings.ini:
org.phoebus.pv.ca/addr_list= 127.0.0.1:6310 org.phoebus.pv.ca/auto_addr_list=false
When you run alarm-server, the following error message is displayed:
2025-04-07 20:26:10 WARNING [org.phoebus.applications.alarm] /Accelerator/xiaomin/TEST:CAT1/test:ai1 connection timed out
When running phoebus, the interface is in the attachment.
Any patches or workarounds for this issue?
I am happy to provide additional logs or configuration files if needed. Thank you for your time and assistance!
Best regards,
xiaomin
Attachment: Screen Capture_select-area_20250407045035.png
Description: Binary data
Prev: Video camera for use in high magnetic field John Dobbins via Tech-talk
Next: SQM-160 protocol files LONG FENG via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Video camera for use in high magnetic field Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
