1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: cross-compiling tirpc header
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Pierrick M Hanlet <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 18 Apr 2025 20:32:57 +0000
Hi Pierrick,
Where in your configure/CONFIG_SITE files are you setting TIRPC=YES?
There are 2 places in Asyn where GnuMake looks at the TIRPC variable. Both asyn/Makefile and testGpibApp/src/Makefile do this:
# Some linux systems moved RPC related symbols to libtirpc
# Define TIRPC in configure/CONFIG_SITE in this case
ifeq ($(TIRPC),YES)
  USR_INCLUDES_Linux += -I/usr/include/tirpc
  asyn_SYS_LIBS_Linux += tirpc
endif
For cross-compilation you really don’t want that to be enabled in either Makefile, so if you’re setting TIRPC=YES in your onfigure/CONFIG_SITE file you also need to set TIRPC=NO in your CONFIG_SITE.Common.linux-arm_raspberrypi5 file. Alternatively only set it to YES in the target-specific CONFIG_SITE.Common.$(T_A) files where those are needed.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 4/18/25, 3:10PM, "Tech-talk" <[email protected]> wrote:
I guess that my real question is, how does one turn "off" the
/usr/include when cross-compiling
On 4/18/25 12:31, Pierrick M Hanlet via Tech-talk wrote:
> [EXTERNAL] – This message is from an external sender
> Greetings all,
> I've recently added the raspberrypi5 platform to my list of supported
> platforms and in attempting to build asyn
> found that I've never correctly pointed my builds to pick up the correct
> header file for tirpc:
> /usr/local/products/buildroot/raspberrypi5_generic/host/usr/bin/aarch64-linux-gcc
> -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET -DUSE_TYPED_DSET
> -DUSE_TYPED_DRVET -DBUILDING_asyn_API   -DUNIX -Dlinux      -O3 -g
> -Wall -Werror-implicit-function-declaration -DUSE_TYPED_RSET
> -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC -DHAVE_CALCMOD
> -DHAVE_DEVINT64       -D_FILE_OFFSET_BITS=64 -g -fPIC -I. -I../O.Common
> -I. -I. -I../../asyn/drvAsynSerial/os/Linux
> -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver
> -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces
> -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions
> -I../../asyn/asynPortDriver -I../../asyn/asynPortClient
> -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11
> -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014
> -I../../asyn/devGpib -I../../include/compiler/gcc
> -I../../include/os/Linux -I../../include
> -I/usr/local/epics/securePVA/Support/ipac/include
> -I/usr/local/epics/securePVA/Support/seq/include
> -I/usr/local/epics/securePVA/Support/calc/include
> -I/usr/local/epics/securePVA/Support/sscan/include
> -I/usr/local/epics/securePVA/base/include/compiler/gcc
> -I/usr/local/epics/securePVA/base/include/os/Linux
> -I/usr/local/epics/securePVA/base/include -I/usr/include/tirpc
> -I/usr/local/products/buildroot/raspberrypi5_generic/host/usr/aarch64-buildroot-linux-gnu/sysroot/usr/include
> -I/usr/local/products/buildroot/raspberrypi5_generic/host/usr/aarch64-buildroot-linux-gnu/sysroot/usr/include/tirpc
> -MM -MF asynManager.d  ../../asyn/asynDriver/asynManager.c
> aarch64-linux-gcc: ERROR: unsafe header/library path used in
> cross-compilation: '-I/usr/include/tirpc'
> In configure/os/CONFIG_SITE.Common.linux-arm_raspberrypi5, I have:
> OP_SYS_INCLUDES+=-I$(GNU_DIR)/$(ARCH_DIR)/sysroot/usr/include
> OP_SYS_INCLUDES+=-I$(GNU_DIR)/$(ARCH_DIR)/sysroot/usr/include/tirpc
> OP_SYS_LDLIBS += -ltirpc
> Should I be using a different environment variable?
> I'm using base-7.0.9 with C++20 on AL9 and asyn-R4-44
> Many thanks,
> Pierrick
> Pierrick Hanlet
> Fermi National Accelerator
> Accelerator Front End Controls
> +1-630-840-5555 -- lab
> +1-312-687-4980 -- mobile
> "Whether you think you can or think you can't, you're right" -- Henry Ford
-- Pierrick Hanlet
+1-630-840-5555 office
+1-312-687-4980 mobile
=== "Whether you think you can or think you can't, either way, you're correct" -- Henry Ford
cross-compiling tirpc header Pierrick M Hanlet via Tech-talk
Re: cross-compiling tirpc header Pierrick M Hanlet via Tech-talk
Prev: Re: cross-compiling tirpc header Pierrick M Hanlet via Tech-talk
Next: Argonne Advanced Photon Source(APS) - Job Posting Sullivan, Joseph via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
