1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Archiver Appliance's Behavior with Large Waveform PVs
From: "Xiao, Lingran via Tech-talk" <[email protected]>
Date: Tue, 22 Apr 2025 21:59:54 +0000
Hi all,
We've observed some unusual behavior from the Archiver Appliance when handling large waveform PVs. The storage rate for one such PV exceeds 800,000 KB/hr. When accessing it via CSS Phoebus or the AA web interface, only live data is displayed, and archived data appears to be inaccessible or more specifically, only one archived data point is displayed. Besides, I noticed that while there is data present in the STS directory, nothing seems to be written to the MTS directory.
A few questions came up:
  • What could be causing this behavior, and is there a known solution?
  • Is there a preferred range of acceptable storage rates?
  • Is there a configuration available to reject storing PVs whose storage rate exceeds a defined threshold?
Also, I have a separate question regarding configuration: Is it possible to configure AA to only record PV data when the value exceeds a specific threshold?
Thanks a lot for your help!
Lingran
Prev: ICALEPCS'25 in Chicago! Abstract submission and registration now open for the 20th International Conference on Accelerator and Large Experimental Physics Control Systems Johnson, Andrew N. via Tech-talk
Next: Support for piezo controller nanoFAKTUR EBD-060310 LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
