1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Compile StreamDevice with PCRE on windows
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: "'Neidherr, Dennis Dr.'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 29 Apr 2025 10:05:33 +0000
Do you have a
....\EPICS\modules\PCRE\lib\windows-x64
directory containing the lib file?  EPICS will use the path  $(PCRE)/lib/$(EPICS_HOST_ARCH)  by default for items mentioned in a RELEASE file, if the lib file is in a different place then you either move it to a directory using this naming or tell EPICS to look in a different place e.g. if it is in ....\EPICS\modules\PCRE\lib then add
pcre_DIR=$(PCRE)/lib
to the stream device Makefile
Freddie
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Neidherr,
> Dennis Dr. via Tech-talk
> Sent: 29 April 2025 10:32
> To: [email protected]
> Subject: Compile StreamDevice with PCRE on windows
> Dear all,
> I just tried to compile StreamDevice on windows with the PCRE package active.
> Without this package everything works fine. But I don't get PCRE working.
> So what did I do:
> I downloaded PCRE (pre-compiled) at Sourceforge as described here
> (https://urldefense.us/v3/__https://paulscherrerinstitute.github.io/StreamD
> evice/setup.html__;!!G_uCfscf7eWS!ZfKA6yWdFPFiCYl7MTE8FME6NieocxQ
> MXHjO3TZUaz5u4e8C3576MhzCkeSlf_dEIJFVlZg4VWcZ7YjAKclB-u7s$ ).
> Then I installed the executable next to my other modules. So it looks like:
> ...\EPICS\modules\asyn-R4-43
> ...\EPICS\modules\StreamDevice-2.8.26
> Then I modified my RELEASE.local file in StreamDevice and added the entry for
> PCRE (between ASYN and Base):
> PCRE=...\EPICS\modules\PCRE (I just deleted the first part of the path here for
> this text)
> But when I try to compile it now, I get the following error:
> make[2]: *** No rule to make target '../../lib/windows-x64/pcre.lib', needed
> by 'stream.dll'.  Stop.
> If I interpret it correctly then he searches for the file "pcre.lib" in
> "...\EPICS\modules\StreamDevice-2.8.26\lib\windows-x64".
> But this is for sure wrong.
> Do I have to add another path somewhere else before compiling?
> I think I will soon switch to linux anyway, so this problem here will solve by
> itself, but nevertheless I would like to know what I am doing wrong.
> Thanks and Greetings
> Dennis
Compile StreamDevice with PCRE on windows Neidherr, Dennis Dr. via Tech-talk
Prev: Compile StreamDevice with PCRE on windows Neidherr, Dennis Dr. via Tech-talk
Next: RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
