1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: EPICS Support for NI-9223
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Mariano Ruiz <[email protected]>
Date: Thu, 15 May 2025 07:34:51 +0000
Hi Mariano
One module is sufficient because we want to interface it with 3 pre-amplifier that are connected to ionization chambers in the XAFS beamline. In terms of hardware, it is recommended to be installed as a standalone module and controlled via Ethernet, for software we prefer a Linux-based EPICS support for faster system integration.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Sent: Thursday, May 15, 2025 10:31 AM
To: Abdalla Ahmad <[email protected]>
Hi Abdalla,
How many modules do you need for your application?
Do you have any other constrains in terms of Operating system to use or hardware interface?
Regards, Mariano
Dr. Mariano Ruiz
Professor
Technical University of Madrid
Instrumentation and Applied Acoustic Research Group
ETS Ingeniería y Sistemas de Telecomunicación
Crta Valencia Km-7
Madrid 28031
Phone(R&D Lab): 913364696 Ext: 29403
Phone: +34910673287
Fax: +34913367801
Mobile: +34696476580
email: [email protected]
http://www.researcherid.com/rid/H-3309-2011
http://orcid.org/0000-0002-1337-0110
Untitled
Disclaimer
This e-mail message may contain confidential information and/or legally privileged and is intended only for the use of the addressed person. Any disclosure, copying, distribution or the taking of any action in reliance on the contents of this e-mail by any other person is strictly prohibited. If you believe that it has been sent to you in error, please reply to the sender that you have received the message in error, then delete this message from your system. Thank you for your cooperation.
Sent: Thursday, May 15, 2025 9:15 AM
Cc: [email protected]
Hi Mariano
I am not sure but does it work as a standalone module? Right now we are checking if it is a suitable replacement for the existing DAQ from Data Translation, the DT8824.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
From: Tech-talk <[email protected]> On Behalf Of Mariano Ruiz via Tech-talk
Sent: Tuesday, May 13, 2025 5:01 PM
To: [email protected]
Subject: FW: EPICS Support for NI-9223
Where do you plan to install the NI-9223?
A cRIO system?
Best regards
Dr. Mariano Ruiz
Professor
Crta Valencia Km-7
Madrid 28031
Phone: +34910673287
Fax: +34913367801
Untitled
Disclaimer
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Tuesday, May 13, 2025 10:45 AM
To: EPICS Tech Talk <
[email protected]>
Subject: Re: EPICS Support for NI-9223
On Tue, 13 May 2025 at 09:58, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
I noticed on the NI section of EPICS manufacturers page https://epics.anl.gov/modules/manufacturer.php#National%20Instruments there is an EPICS driver for the NI-DAQmx interface which, according to NI website, works with the NI-9223 but the SVN URL ( http://epics.svn.sourceforge.net/viewvc/epics/applications/trunk/DAQmxBase/ ) is not working. Is there another URL to clone the driver? Will this driver work with the NI-9223? Are there other alternatives?
FWIW, the modules database has moved to https://epics-controls.org/resources-and-support/modules/ a few years ago.
Note that DAQmx and DAQmx Base are two different NI software products. DAQmx Base development was frozen by NI in 2019 (last release: 2015).
ITER has plain EPICS support and an NDSv3 device driver for the IRIO library (by the I2A2 institute of UPM - University of Madrid) on top of the NI DAQmx open source driver (yet another NI driver). [1]
The first official release of the IRIO-based stack was also announced on Tech-Talk [2] and later reported in the EPICS Collaboration Meeting in June 2019. [3]
NDSv3 is the C++ framework for data acquisition that ITER proposes for its diagnostics use cases. It was presented in more detail at the ICALEPCS 2021. [4]
We're currently in the middle of the procedure to make the ITER developments for NDSv3 public. Once we have the authorization, things will appear on GitHub.
Cheers,
~Ralph
EPICS Support for NI-9223 Abdalla Ahmad via Tech-talk
Re: EPICS Support for NI-9223 Ralph Lange via Tech-talk
FW: EPICS Support for NI-9223 Mariano Ruiz via Tech-talk
RE: EPICS Support for NI-9223 Abdalla Ahmad via Tech-talk
Prev: RE: EPICS Support for NI-9223 Abdalla Ahmad via Tech-talk
Next: RE: EPICS Support for NI-9223 Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Custom filters Lucas Magalhães via Tech-talk
