Hi Marc,
ahh, thanks. Good to know that there is a difference also for other fields.
Greetings Dennis
Sent: Donnerstag, 15. Mai 2025 14:41
To: tech-talk at aps.anl.gov; Neidherr, Dennis Dr. <D.Neidherr at gsi.de>
Subject: Re: camonitor the PACT field
The PACT field does not send monitor events, so you can read it, but not monitor it.
The old EPICS Record Reference Manual makes this clear. Note that the Rec Proc Monitor column is No for the PACT field.
Unfortunately, the new EPICS 7 Record Reference Manual does not have a column that indicates whether fields generate monitors.
For example, in the old manual it is clear that the STAT and SEVR fields generate monitors, but in the new manual that information is missing.
Dear all,
I have again a small question, this time about the reading out of the PACT field:
For this test I am using a small StreamDevice record which communicates with a connected device. If I execute the processing of this record and use a python script to monitor the status of the PACT field via cagets in a loop, I receive exactly what I expected,
so the value of this field changes from 0 to 1 and back to 0. But if I try this with a camonitor (or a pvmonitor) no change is recognized. This also happens in a command prompt so it is no problem of the python library I am using.
Is this a normal behavior?
Thanks in advance, Greetings
Dennis
- camonitor the PACT field Neidherr, Dennis Dr. via Tech-talk
- Re: camonitor the PACT field Mark Rivers via Tech-talk
Re: [Ext]How to use Optics Slit records with absolute encoders? Jesse Hopkins via Tech-talk
<2025>
Re: camonitor the PACT field Johnson, Andrew N. via Tech-talk
<2025>
ANJ, 15 May 2025 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
