1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: Suggestions wanted on IOC hardware
From: "J. Lewis Muir via Tech-talk" <tech-talk at aps.anl.gov>
To: "James P. Withrow" <jwithrow at cornell.edu>
Cc: "Tech-talk at aps.anl.gov" <Tech-talk at aps.anl.gov>
Date: Wed, 21 May 2025 10:07:20 -0500
On 05/21, James P. Withrow via Tech-talk wrote:
> I'm investigating the eventual migration of our control system to EPICS, and as such, I would like to solicit community input on IOC hardware which I can use as a 'boilerplate' configuration for common tasks like sensor (I2C/SPI) polling, instrumentation (RS232/485), and general IO.
Hi, Jim!
Mark Rivers has designed, implemented, and documented a solution for
replacing VME-based IOCs with x86-64-based IOCs:
  https://urldefense.us/v3/__https://github.com/CARS-UChicago/GSECARS-EPICS/blob/master/docs/Replace_VME/ReplaceVME.pdf__;!!G_uCfscf7eWS!ZNOlk2G3OhVLMrgf9ESSEHRywCHb_eFtLPR0N-XOVGwH-OMyRczbD1OOd8ylpNb2JuJgFBBUr2_eUBQoZjLYSA$
I think it's very good, but of course it depends on what you want to do.
Lewis
RE: Suggestions wanted on IOC hardware Mark Rivers via Tech-talk
Suggestions wanted on IOC hardware James P. Withrow via Tech-talk
Prev: Suggestions wanted on IOC hardware James P. Withrow via Tech-talk
Next: RE: Suggestions wanted on IOC hardware Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
ANJ, 21 May 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
