On 5/23/25 08:06, Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk wrote:
Hello Tech Talk,
Could I please get some directions to the exact bit of code that processes a UDP message and iterates through the list of PVs to see if that IOC has it? I get as far as "camessage" in "camessage.c", but can't seem to find the next processing step.
For each UDP packet, there is an indirection through 'udpJumpTable[]' to reach udp_version_action()
once, and search_reply_udp() many times. I expect that the majority of the time in the later will
be spent in 'dbChannelTest()' which does the hash table lookup of local record names.
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/blob/c67982aa3f3660aace9832225b2e798317133db2/modules/database/src/ioc/rsrv/camessage.c*L2167__;Iw!!G_uCfscf7eWS!dBHoDebKrIPXx0d5NmypWg4DHjOBQrFoIjpXkWTGadJpih3EfoJDqUPtnlWQvXcRjetXWMWu7CEq_nKrbLMjosQ3fg$
I ask as I think I need to implement tracing in this function (CASDEBUG doesn't give me enough). I have one particular IOC that is regularly using 20+% CPU on the "CAS-UDP" task (as reported by "rt cpuuse"). I will note that it works fine in two other near-identical IOCs, and has also reoccurred despite replacing a lot of the hardware, so I'm currently investigating whether it's an EPICS UDP software issue.
For reference this is me continuing investigations started in this TechTalk thread: https://epics.anl.gov/tech-talk/2025/msg00318.php <https://epics.anl.gov/tech-talk/2025/msg00318.php >
Thank you,
Alex Wells
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
- EPICS Channel Access UDP Processing Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
Re: Diagnosing and overcoming GigE camera freezes Henrique F. Simoes via Tech-talk
<2025>
2026
Installing .req files via DB vs. REQ? J. Lewis Muir via Tech-talk
<2025>
2026
