1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Eaton UPS Network-M3
From: Marco Filho via Tech-talk <[email protected]>
To: boj <[email protected]>, "[email protected]" <[email protected]>, Freddie Akeroyd - STFC UKRI <[email protected]>
Date: Fri, 30 May 2025 07:53:13 +0000
Hello
The SNMP epics module worked fine for Eaton UPS automation here at ESS.
You have to activate the SNMP agent in the web GUI, there should be a section for that.
Also, there are specific MIB files that you should download from the device and include in your IOC with
epicsEnvSet("MIBDIRS", "+$(snmp_DIR)/db")
Or similar... (in this case we are pointing to a patched version that has the Eaton MIBS included in it, but I don't think they come by default on the SNMP module)
Cheers
From: Tech-talk <[email protected]> on behalf of Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
Sent: Wednesday, May 28, 2025 13:15
To: boj <[email protected]>; [email protected] <[email protected]>
Subject: RE: Eaton UPS Network-M3
Hi Bo,
It looks like the UPS supports SNMP  "MIB II – Standard IETF UPS MIB (RFC 1628) – Eaton xUPS MIB" so if it exposes the information you need by this route you should be able to monitor using the EPICS SNMP module  https://urldefense.us/v3/__https://groups.frib.msu.edu/controls/files/devSnmp.html__;!!G_uCfscf7eWS!dlxa2rKzQLDGdYbWcInez0AVIfntphYEDOxl4mAWkjnBkjEiVDRrp5IR_eQc7HqqDFvslT5MbKHY3UEk5wZFl_VVb-rN-XOU0XM$
Freddie
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of boj via Tech-talk
Sent: 28 May 2025 10:43
To: [email protected]
Subject: Eaton UPS Network-M3
Dear all
I am upgrading out labs with Eaton UPS's (9PX 3000) which I have got with the Netwoek-m3 ethernet card.
I was hoping to implement EPICS support for logging the status, but unfortunately it does not seems to be straight forward as the web interface does not have a simple API.
So I would like to hear if anyone here has attempted communication with such EATON Ups's
Best regards
Bo
Re: Eaton UPS Network-M3 boj via Tech-talk
RE: Eaton UPS Network-M3 Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: AreaDetector Collaboration Meeting - June 5th Érico Nogueira Rolim via Tech-talk
Next: RE: Understand put requests Zhang, Tong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: Eaton UPS Network-M3 Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: Eaton UPS Network-M3 boj via Tech-talk
