1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Help operating ADHamamatsuDCAM IOC
From: Marco Filho via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 9 Jul 2025 11:36:58 +0000
Good afternoon, all
We are trying out the latest version of the ADHamamatsuDCAM EPICS module (https://github.com/areaDetector/ADHamamatsuDCAM) to operate a C13440 model.
Everything seems to work out mostly fine, except we get an empty image no matter how we configure the camera.
For now, I tried running the following IOC:
epicsEnvSet("PREFIX", "13HAMA1:")
epicsEnvSet("PORT",   "HAMA1")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "1024")
epicsEnvSet("YSIZE",  "1024")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CBUFFS", "500")
epicsEnvSet("MAX_THREADS", "8")
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db")
# Create a hamamatsu driver
# hamamatsuConfig(const char *portName, int camIndex, int maxBuffers, int maxMemory, int priority, int stackSize)
hamamatsuConfig("$(PORT)", 0, 0, 0, 99)
# To have the rate calculation use a non-zero smoothing factor use the following line
dbLoadRecords("$(adhamamatsudcam_DB)/hamamatsu.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
NDStdArraysConfigure("Image1", 20, 0, "$(PORT)", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=UCHAR,NELEMENTS=12000000")
iocInit
dbpf 13HAMA1:image1:EnableCallbacks 1
dbpf 13HAMA1:cam1:HamaRegionReset 1
dbpf 13HAMA1:cam1:AcquirePeriod 1.1
dbpf 13HAMA1:cam1:SizeX 1024
dbpf 13HAMA1:cam1:SizeY 1024
After that, clicking on acquire start I can see the number of images incrementing both on the driver and on the image plugin, but the image is always empty:
> dbgf 13HAMA1:image1:ArrayData
DBF_UCHAR[800]:     0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0
0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0   0 = 0x0 (...)
Does anyone have experience with this camera and knows if we are misconfiguring some parameter?
I attach a picture of the operation screen after acquiring  if that is of any help. I noticed the region size X and Y start as 1, so I guessed that putting some bigger value on that would be needed to make the image work...
Thanks in advance for any help,
Marco
RE: Help operating ADHamamatsuDCAM IOC Mark Rivers via Tech-talk
Prev: Re: Eurotherm 3200 serials Heinz Junkes (FHI) via Tech-talk
Next: EPNix 25.05 released NICOLE Rémi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: RE: Help operating ADHamamatsuDCAM IOC Mark Rivers via Tech-talk
