Hi Federico!
Per the log below, you seem to be interrupting your build:
-I/home/xlabsrv11/epics/dbd -o hvps_example.dbd base.dbd
^Cmake[2]: *** [/home/xlabsrv11/epics/configure/RULES_ARCHS:58:
install.linux-x86_64] Interruzione
make[1]: *** [/home/xlabsrv11/epics/configure/RULES_DIRS:85:
src.install] Interruzione
make: *** [/home/xlabsrv11/epics/configure/RULES_DIRS:85:
hvps_exampleApp.install] Interruzione
"^C" usually indicates someone pressed Ctrl-C in their terminal, and
that's compatible with the "Interruzione" messages in the later lines.
About your PS, have you gone through
https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/getting-started/EPICS_Intro.html__;!!G_uCfscf7eWS!bNMx61hJ0gIf3PejYK17rNHHZeWf5CMTFzoMQj7n8jXNJYEYSSS6ayEEyq-XbsJzHy8bhB_hYid6PhKVvcZLE3rTPH8$
and
https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/getting-started/installation-linux.html__;!!G_uCfscf7eWS!bNMx61hJ0gIf3PejYK17rNHHZeWf5CMTFzoMQj7n8jXNJYEYSSS6ayEEyq-XbsJzHy8bhB_hYid6PhKVvcZLyJMrE_k$
Cheers,
Érico
On 21/07/2025 12:24, Federico Galdenzi via Tech-talk wrote:
> Dear Simon,
> Thanks for the reply. I'm not very familiar with C but i'm trying to
> fill the gaps. However the building fails because the warning gets
> triggered continously and the building doesnt' go further. It just
> keeps printing the warning.
> Il 2025-07-21 16:33 Simon Rose ha scritto:
>> Hi Federico -
>> Make uses the timestamp on files to detect if a file needs to be
>> updated. It seems that one of your files thinks it was created about
>> 6 years from now.
>> I've seen this come up in a few odd ways, possibly due to thinks like
>> mounted filesystems on hosts that have different time settings, or
>> improper NTP syncing.
>> That said, that shouldn't actually cause the build to fail; that's
>> just a warning that something is a bit off with the latest
>> modification time of that file. It can be ignored, although it's
>> probably worth looking at why your file and systems times do not
>> match each other.
>> Cheers,
>> Simon
>> On 2025-07-21, 16:17, "Tech-talk on behalf of Federico Galdenzi via
>> Tech-talk" <[email protected]
>> <mailto:[email protected]> on behalf of
>> [email protected] <mailto:[email protected]>> wrote:
>> Dear Community,
>> I'm trying to learn EPICS and i started following a pretty simple
>> example from Maurizio Monti, stream device exercises. I wanted to create
>> a simple EPICS application that controls VPS. However, after setting up
>> everything, I get into this error.
>> make[3]: Attenzione: il file
>> "/home/xlabsrv11/epics/configure/RULES_COMMON" ha un orario di modifica
>> 209019432 nel futuro
>> Creating dbd file hvps_example.dbd
>> perl -CSD /home/xlabsrv11/epics/bin/linux-x86_64/dbdExpand.pl -I. -I..
>> -I../O.Common -I../../../dbd
>> -I/home/xlabsrv11/epics/synApps_6_3/support/asyn-R4-44-2/dbd
>> -I/home/xlabsrv11/epics/synApps_6_3/support/StreamDevice-2-8-24/dbd
>> The "make[3]: warning" translates to " the file ../../.. has a different
>> modification time 209019432 in the future".
>> Can you help me?
>> ps: as a side note, i'd like to know if you can suggest me some
>> resources for learning epics. I'm kinda lost sometimes.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Strange Make Error Federico Galdenzi via Tech-talk
- Re: Strange Make Error Simon Rose via Tech-talk
- Re: Strange Make Error Federico Galdenzi via Tech-talk
Re: Strange Make Error Torsten Bögershausen via Tech-talk
Re: Strange Make Error Johnson, Andrew N. via Tech-talk
<2025>
2026
Re: Strange Make Error Maren Purves via Tech-talk
Support for DBR_INT64 missing in caget/camonitor? Heinz Junkes (FHI) via Tech-talk
<2025>
2026
