Hello Eddy
I have implemented your request. See latest commit 5ae38a08.
https://urldefense.us/v3/__https://github.com/paulscherrerinstitute/StreamDevice/commit/5ae38a08__;!!G_uCfscf7eWS!cAw9XzrsbzJkeIaTJbCHGITiBrLKBpAF9UPGNJsfAFSd7i_i4yL_A9_NL8SDU87mR-hs6DRqHgTTqdb0ORwuRDxFFQ$
Now, if using the + flag ("%+x" or "%+X"), the value will be interpreted as a
signed hex number. That means it will be sign extended if the most significant
hex digit is 8 or higher. But if width is given, width characters must have been
read:
in "%+x"; sign extends "80", " 9", "0xf", "abcd" but not "0x0f" or "0fed"
in "%+4x"; sign extends "abcd" and "0xf0" but not "abc" or "0xf"
Dirk
On Mon, 2025-09-15 at 10:28 +0200, Zimoch Dirk wrote:
> Hello Eddy
> Signed %x input is currently not supported by StreamDevice but it is definitely
> useful to have. I have to think how to implement it and which flag to use to
> signal the switch from normal unsigned %x.
> Dirk
> On Mon, 2025-09-15 at 08:04 +0000, Blomley, Edmund (IBPT) via Tech-talk wrote:
> > Hey,
> > So my device sends me a 4 bit hex which I convert to a float using an ai record and linear conversion with ESLO.
> > Let’s ignore the conversion for now, the number needs to be treated as a signed long, so I need to get the 2’s complement:
> > 07D0 -> 2000
> > F6F5 -> -2315
> > Is there a way to do this directly with streamdevice?
> > If not, I would need to read in the raw long and convert it myself. What is the best approach to do the conversion with records?
> > So far I would do:
> > field(CALC, "65535 - A + 1") with A being the raw long.
> > Cheers
> > eddy
- Parse Hex into signed number with streamdevice? Blomley, Edmund (IBPT) via Tech-talk
- Re: Parse Hex into signed number with streamdevice? Zimoch, Dirk via Tech-talk
<2025>
<2025>
