1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Fast stream-device IOC suddenly disconnects
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "Zimoch, Dirk" <[email protected]>
Date: Sun, 28 Sep 2025 11:50:20 +0000
Hello Dirk
I have attached the protocol files as well as two databases, the IOC first reads the raw data and then process a group of PVs sequentially as seen by the chain of forward-links. When the issue happens, the first PV in the chain “:Raw$(CH)” is frozen.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Sent: Sunday, September 28, 2025 2:38 PM
To: Abdalla Ahmad <[email protected]>
Cc: [email protected]
Subject: Re: Fast stream-device IOC suddenly disconnects
Hello Abdalla
Please provide records and protocol file. Can you reproduce this with a simulated device that you can provide as well?
Dirk
Am 28.09.2025 um 13:08 schrieb Abdalla Ahmad via Tech-talk <[email protected]>:
Hi
We have a device streaming data at 200 Hz controlled with stream device, parses the streamed data and writes to corresponding PVs. The problem is that every day or two, the readings freeze. At first I had to restart the IOC but I noticed that the IOC does not show any error so I re-connect the asyn port through writing 0 to the CNCT field and it worked. The st.cmd file has the port configured:
drvAsynIPPortConfigure(“PORT”, “ip-address:port-number”, 0, 0, 0)
What could be the issue here? I am using EPICS base 7.0.9 and latest version of all modules.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Attachment: controller.db
Description: controller.db
Attachment: vibration.proto
Description: vibration.proto
Re: Fast stream-device IOC suddenly disconnects Zimoch, Dirk via Tech-talk
Fast stream-device IOC suddenly disconnects Abdalla Ahmad via Tech-talk
Prev: Re: Fast stream-device IOC suddenly disconnects Zimoch, Dirk via Tech-talk
Next: Re: Fast stream-device IOC suddenly disconnects Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Fast stream-device IOC suddenly disconnects Zimoch, Dirk via Tech-talk
