1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Fast stream-device IOC suddenly disconnects
To: Abdalla Ahmad <[email protected]>
Cc: [email protected]
Date: Sat, 4 Oct 2025 18:36:12 -0400
Could this be some type of interaction with software flow control?
John
On Oct 3, 2025, at 2:12 PM, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
Hello Mark
I wanted to wait for it to disconnect again to investigate further, unfortunately still the ioc shell shows no error messages and the terminal statistics just stops counting. I know disconnectOnReadTimeout will solve it but I really want to troubleshoot further and see if something can be done on the device's firmware side because we changed the terminal server two times with the same scenario.
Best Regards
Abdalla
Sent: Friday, October 3, 2025 5:18:24 PM
Cc: [email protected] <[email protected]>
Hi Abdalla,
I’ve made 3 suggestions:
- Set disconnectOnReadTimeout
- Log all communication to see if it stops
- Look at the statistics in the terminal server
Have you tried these?
Sent from my iPhone
On Sep 28, 2025, at 10:08 AM, Abdalla Ahmad <[email protected]> wrote:
Hi Mark
Thanks for the info. I forgot to mention that the device is a serial port connected to a terminal server, and the device has been tested locally streaming data for periods longer than what we have so I don't think it just stopped sending data.
Best Regards
Abdalla.
Sent: Sunday, September 28, 2025 5:02:36 PM
To: [email protected] <[email protected]>; Abdalla Ahmad <[email protected]>
Hi Abdalla,
It looks like the device streams data without needing to send a command, i.e. it is not a write/read operation, correct?
If it freezes then that suggests that the device has stopped sending data for some reason.  That should mean that the asyn read operation timed out, and StreamDevice should be reporting that?
You can try adding this to the startup script after drvAsynIPPortConfigure:
asynSetOption($(PORT), 0, "disconnectOnReadTimeout", "Y")
That will disconnect the port when a read times out, which is equivalent to writing 0 to the CNCT field.
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Sunday, September 28, 2025 6:08 AM
Subject: Fast stream-device IOC suddenly disconnects
Hi
We have a device streaming data at 200 Hz controlled with stream device, parses the streamed data and writes to corresponding PVs. The problem is that every day or two, the readings freeze. At first I had to restart the IOC but I noticed that the IOC does not show any error so I re-connect the asyn port through writing 0 to the CNCT field and it worked. The st.cmd file has the port configured:
drvAsynIPPortConfigure(“PORT”, “ip-address:port-number”, 0, 0, 0)
What could be the issue here? I am using EPICS base 7.0.9 and latest version of all modules.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Re: Fast stream-device IOC suddenly disconnects Abdalla Ahmad via Tech-talk
Prev: Re: Fast stream-device IOC suddenly disconnects Mark Rivers via Tech-talk
Next: Basic EPICS bootstrap (rant) Graeme Winter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Strange error in building IOC with Sequencer support Dudley, David via Tech-talk
