1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Basic EPICS bootstrap (rant)
From: Graeme Winter via Tech-talk <[email protected]>
Date: Tue, 7 Oct 2025 19:14:48 +0000
Thanks Mark, I suspect this is the bootstrap type process I was looking for
Appreciated,
Best wishes Graeme
On 7 Oct 2025, at 14:10, Mark Rivers <[email protected]> wrote:
Hi Graeme,
I don’t know of a general solution for your problems, but the epics-synApps module (https://github.com/EPICS-synApps) provides 2 useful tools:
  • assemble_synApps “Used to pull a user-defined set of EPICS modules at given tags and package them into a single synApps directory that will build with a single 'make' command.”
You can instruct it to create a full clone, so that in the future each module can be updated independently.
  • support:  Top-level Makefile supports “make release”.  You edit support/configure/RELEASE to define the versions and locations of each module.  “make release” will update the configure/RELEASE files in all modules to be consistent with support/configure/RELEASE.
These are used by most beamlines at the APS.
From: Tech-talk <[email protected]> On Behalf Of Graeme Winter via Tech-talk
Sent: Tuesday, October 7, 2025 1:56 PM
To: [email protected]
Subject: Basic EPICS bootstrap (rant)
Good afternoon
Working through
It really feels like this is something which could be made _much_ easier by writing a kind of bootstrap script but also by the configure process being able to pick up stuff from the environment rather than having to hard-code every location multiple times in every configuration file (where the defaults are of course where the author does _their_ epics development) - the need for them to all correctly cross-reference is also an irritation
Before I scrape another few mm off my already suffering sanity -
- _has_ anyone got a bootstrap script which will clone / install all the necessary / regular support modules
- am I holding it wrong / reading the wrong getting started guide
I note I can conda install epics-base but this _only_ gives epics base
That rant to one side, also, does anyone know how to address a missing symbol issue like
Undefined symbols for architecture arm64:
  "_pvar_func_vxi11RegisterCommands", referenced from:
      _cryo1_registerRecordDeviceDriver in cryo1_registerRecordDeviceDriver.o
ld: symbol(s) not found for architecture arm64
The symbol is indeed missing and would appear to be from asyn/vxi11/drvVxi11.c but does not appear to be built
This got me thinking I should re-do the NN steps to get back to here which then got me wondering about process itself…
Thanks Graeme
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Basic EPICS bootstrap (rant) Graeme Winter via Tech-talk
RE: Basic EPICS bootstrap (rant) Mark Rivers via Tech-talk
Prev: RE: Basic EPICS bootstrap (rant) Mark Rivers via Tech-talk
Next: Waveform VAL fields in newer versions of EPICS Baily, Scott A via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Basic EPICS bootstrap (rant) Han Lee via Tech-talk
