1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: areadetector PV for pilatus3 retrigger and count-rate correction
From: Keith Surrena via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Oct 2025 15:39:03 +0000
Hi Mark,
This is for our pilatus3 X 6M, so within this manual https://media.dectris.com/user-manual-pilatus3-2020_GOKBotG.pdf. The specific commands are SetRetriggerMode and RateCorrLUTDir
Sent: Tuesday, October 28, 2025 11:30 AM
To: Keith Surrena <[email protected]>; [email protected]
Hi Keith,
Those commands are not supported in ADPilatus.
I just searched this Dectris camserver document for the string “retrigger” and it does exist.
https://media.dectris.com/User_Manual-PILATUS2-V1_4.pdf
Where did you find the documentation on the retrigger command?
I do see the documentation on the Tau command.  ADPilatus currently only reads Tau, it does not allow setting it.
However, you can set it via the OPI screens as follows:
  • In the screen pilatusDetector.adl open the Debugging/asyn record screen.
  • Change the port on that screen to camserver (if that is what you called it in the startup script).
  • Open the More/asynOctet interface I/O screen
  • In the Output/ASCII screen type the camserver command.  You will see the response in the Input/ASCII field.
I just tested this typing “Tau” to read the current setting, and I received the correct response.
From: Tech-talk <[email protected]> On Behalf Of Keith Surrena via Tech-talk
Sent: Tuesday, October 28, 2025 9:51 AM
To: [email protected]
Subject: areadetector PV for pilatus3 retrigger and count-rate correction
Are there PVs that exist for adjusting these parameters? Alternatively, since I know the specific camserver commands, is there a PV I can use to manually send strings to camserver? I noticed that there is a StringToCamserver_RBV, which piques my interest.
Keith Surrena
Research Support Specialist
Cornell High Energy Synchrotron Source
writing a value of a string PV to a waveform PV in another IOC Gregory, Ray via Tech-talk
areadetector PV for pilatus3 retrigger and count-rate correction Keith Surrena via Tech-talk
RE: areadetector PV for pilatus3 retrigger and count-rate correction Mark Rivers via Tech-talk
Prev: RE: areadetector PV for pilatus3 retrigger and count-rate correction Mark Rivers via Tech-talk
Next: Re: Tech-talk Digest, Vol 19, Issue 478 Hong, Ran via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: writing a value of a string PV to a waveform PV in another IOC Gregory, Ray via Tech-talk
