1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Anyone using Zaber motion controllers?
From: Laurenz Rettig via Tech-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>, [email protected], Ralph Lange <[email protected]>
Date: Thu, 6 Nov 2025 10:57:30 +0100
Yes, I think this is using this binary protocol:
https://urldefense.us/v3/__https://www.zaber.com/w/Manuals/Binary_Protocol_Manual__;!!G_uCfscf7eWS!ZCj-YSJc2mHFFxr1Iwa7LWm_qKkyXfIkKBN_fmWYktGO75anQy1YUUzusFvvBx7lXnqP0IEaBO6sFzCWZ6wHKhr2H4vr$
Best, Laurenz
On 06.11.2025 10:48, Torsten Bögershausen wrote:
Thanks.
Not having digged into StreamDevice for a long time:
It looks as if your database is using a binary communication ?!
But yes, it should be "easy" to write a proper motor driver.
Or use the soft motor.
/Torsten
On 2025-11-06 10:09, Laurenz Rettig wrote:
Hi Torsten,
I added the files here: https://urldefense.us/v3/__https://github.com/rettigl/epics_zaber_mirror__;!!G_uCfscf7eWS!ZCj-YSJc2mHFFxr1Iwa7LWm_qKkyXfIkKBN_fmWYktGO75anQy1YUUzusFvvBx7lXnqP0IEaBO6sFzCWZ6wHKu271Cvb$
Best, Laurenz
On 06.11.2025 09:57, Torsten Bögershausen wrote:
Hej Laurenz,
Is there a public Gir repo for your streamdevice files ?
As Matt pointed out, the streamdevice files may be a starting
point to develop a model 3 motor driver.
Which does support motorRecord and does support other records.
Advanced note:
It is possible to put a "softMotor" on top of EPICS records:
You need to have input records for:
a) The actual position of the motor
b) Is the motor "done" (the opposite of busy)
c) You need an output record where the softMotor
can write the new target position, where the motor should move to.
(End of advanced comments)
/Torsten
On 2025-11-05 09:57, Laurenz Rettig via Tech-talk wrote:
We are using a stepper motor controlled mirror holder from Zaber, which we control via stream device. No proper Epics motor support, though. I could share the support files, if of interest.
Best, Laurenz
On 05.11.2025 09:24, Ralph Lange via Tech-talk wrote:
Of ITER's many Diagnostics systems, one plans to use a Zaber linear stage.
Is anyone using Zaber devices?
Zaber has an open-source high-level library (Zaber Motion Library) written in Go with wrappers for a bunch of languages, on top of an ASCII-over-TCP protocol. Any experiences with that?
Thanks for any leads...
~Ralph
Dr. Laurenz Rettig                  [email protected]
Emmy Noether Research Group Dynamics of Correlated Materials
Fritz Haber Institute of the Max Planck Society
Department of Physical Chemistry
Faradayweg 4-6                         Tel: +49 30 8413 5225
14195 Berlin, Germany                  Fax: +49 30 8413-5387
Re: Anyone using Zaber motion controllers? Wlodek, Jakub via Tech-talk
Anyone using Zaber motion controllers? Ralph Lange via Tech-talk
Re: Anyone using Zaber motion controllers? Laurenz Rettig via Tech-talk
Re: Anyone using Zaber motion controllers? Torsten Bögershausen via Tech-talk
Prev: Re: Anyone using Zaber motion controllers? Torsten Bögershausen via Tech-talk
Next: Re: Anyone using Zaber motion controllers? Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
