1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: pvxs Access/list problem
From: "Heinz Junkes \(FHI\) via Tech-talk" <[email protected]>
To: Mark Rivers via Tech-talk <[email protected]>
Date: Mon, 10 Nov 2025 10:34:35 +0100
I have RTEMS with EPICS7/PVXS running on the IOC.
gonzo> pvxsi
Host: linux-x86_64
Target: RTEMS-beatnik RTEMS gcc
Toolchain
    __cplusplus = 201103
    GCC 15.2.0
    _GLIBCXX_USE_CXX11_ABI = 1
    __GLIBCXX__ 20250808
Versions
    PVXS 1.4.0 (1.4.0-4-g021bcb4a06224ed8c0e8-dirty)
    EPICS 7.0.9.1-DEV
    libevent 2.2.0-alpha-dev
Runtime
    uname() -> RTEMS Node 1 7.0.0  PowerPC/Generic (classic FPU)
    epicsThreadGetCPUs() -> 1
    osiLocalAddr() -> 141.14.128.12
    osiSockDiscoverBroadcastAddresses() ->
        141.14.143.255
Effective Client config from environment
    EPICS_PVA_ADDR_LIST1.14.143.255
    EPICS_PVA_AUTO_ADDR_LIST=NO
    EPICS_PVA_BROADCAST_PORTP76
    EPICS_PVA_CONN_TMO0
    EPICS_PVA_INTF_ADDR_LIST=0.0.0.0
    EPICS_PVA_NAME_SERVERS    EPICS_PVA_SERVER_PORTP75
Effective Server config from environment
    EPICS_PVAS_AUTO_BEACON_ADDR_LIST=NO
    EPICS_PVAS_BEACON_ADDR_LIST1.14.143.255
    EPICS_PVAS_BROADCAST_PORTP76
    EPICS_PVAS_IGNORE_ADDR_LIST    EPICS_PVAS_INTF_ADDR_LIST=0.0.0.0
    EPICS_PVAS_SERVER_PORTP75
Server:
gonzo> pvxsr
EPICS_PVAS_IGNORE_ADDR_LISTEPICS_PVAS_INTF_ADDR_LIST=0.0.0.0
Source: __builtin prio=-1
Source: __server prio=-1
Source: qsrvSingle prio=0
Source: qsrvGroup prio=1
PVs:
gonzo> pvxsl
my:custom:pv
rtems:aSubExample
rtems:ai1
myExampleApp/src/pvxsAddPV.cpp
#include <pvxs/iochooks.h>
#include <pvxs/sharedpv.h>
#include <pvxs/server.h>
#include <pvxs/nt.h>
#include <initHooks.h>
#include <epicsExport.h>
using namespace pvxs;
static void myinitHook(initHookState state) {
    if(state != initHookAfterIocBuilt)
        return;
    // Create a SharedPV
    auto initial = nt::NTScalar{TypeCode::Float64}.create();
    initial["value"] = 42.0;
    auto pv = server::SharedPV::buildMailbox();
    pv.open(initial);
    // Add to the running QSRV2 server
    ioc::server().addPV("my:custom:pv", pv);
static void myregistrar() {
    initHookRegister(&myinitHook);
extern "C" {
    // needs matching "registrar(myregistrar)" in .dbd
    epicsExportRegistrar(myregistrar);
When I try to access the PVs via pva, it doesn't work, and unfortunately I don't understand where the problem could be.
Broadcast pvlist does not show up the IOC (141.14.128.12)
(base) hactar:~ junkes$ pvlist
GUID 0x0D5DC20423F82D6367A9991D version 2: tcp@[ 141.14.131.228:42479 ]
GUID 0x29A411690000000047502D2E version 2: tcp@[ 141.14.137.64:5075 ]
GUID 0x3BD94CBB98B48A44F3222CAA version 2: tcp@[ 141.14.137.82:5075 ]
GUID 0x3D28C96800000000332CF600 version 2: tcp@[ 141.14.135.248:5075 ]
GUID 0x412CE9BBB99971C4925B7F98 version 2: tcp@[ 141.14.136.101:5075 ]
GUID 0x78A51380147E8E0A16815C4A version 2: tcp@[ 141.14.135.182:43725 ]
GUID 0x7F1F3778BDA21463248755EF version 2: tcp@[ 141.14.135.181:39019 ]
GUID 0x9E7BB02B21880EF8374DC25A version 2: tcp@[ 141.14.135.182:5075 ]
GUID 0xA2D6A7048B0325099A66752E version 2: tcp@[ 141.14.135.181:5075 ]
GUID 0xADE023B474DF8FD6ACC071D7 version 2: tcp@[ 141.14.131.228:5075 ]
GUID 0xB2FA0D6900000000E447A310 version 2: tcp@[ 141.14.135.73:5075 ]
GUID 0xBD17A7945C075D000CB3D8FA version 2: tcp@[ 141.14.136.102:5075 ]
GUID 0xC0C2E391F3D2CD759A1A9506 version 2: tcp@[ 141.14.140.98:5075 ]
GUID 0xEE4C0E6900000000842D1610 version 2: tcp@[ 141.14.137.80:5075 ]
GUID 0xF2D7806100000000509A8E35 version 2: tcp@[ 141.14.136.67:5075 ]
GUID 0xF3072338078D3E052A4F58E4 version 2: tcp@[ 141.14.134.173:5075 ]
Unicast request show the PVs:
(base) hactar:~ junkes$ pvlist 141.14.128.12
my:custom:pv
rtems:aSubExample
rtems:ai1
Debug :
(base) hactar:~ junkes$ pvlist -d
2025-11-10T10:04:36.351 Broadcast address #0: 141.14.128.12:5076.
2025-11-10T10:04:36.352 UDP Tx (37) -> 141.14.128.12:5076
(base) hactar:~ junkes$ pvlist -d 141.14.128.12
Query to 141.14.128.12
epics:nt/NTURI:1.0
    string scheme pva
    string path server
    structure query
        string op channels
2025-11-10T10:05:23.018 Creating datagram socket from: 0.0.0.0:52478.
2025-11-10T10:05:23.018 Broadcast address #0: 141.14.128.12:5076. (unicast)
2025-11-10T10:05:23.018 Setting up UDP for interface 141.14.128.70/255.255.240.0, broadcast 141.14.143.255, dest <none>.
2025-11-10T10:05:23.018 Creating datagram socket from: 141.14.128.70:5076.
2025-11-10T10:05:23.018 Creating datagram socket from: 141.14.143.255:5076.
2025-11-10T10:05:23.019 Setting up UDP for interface 169.254.104.63/255.255.0.0, broadcast 169.254.255.255, dest <none>.
2025-11-10T10:05:23.019 Creating datagram socket from: 169.254.104.63:5076.
2025-11-10T10:05:23.019 Creating datagram socket from: 169.254.255.255:5076.
2025-11-10T10:05:23.019 Creating datagram socket from: 224.0.0.128:5076.
2025-11-10T10:05:23.019 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
Execute
2025-11-10T10:05:23.019 Connecting to PVA server: 141.14.128.12:5075.
2025-11-10T10:05:23.019 Opening socket to PVA server 141.14.128.12:5075, attempt 1.
2025-11-10T10:05:23.019 Socket connected to PVA server: 141.14.128.12:5075.
2025-11-10T10:05:23.019 Acquiring transport to 141.14.128.12:5075.
2025-11-10T10:05:23.022 Connected to PVA server: 141.14.128.12:5075.
2025-11-10T10:05:23.023 Releasing TCP transport to 141.14.128.12:5075.
2025-11-10T10:05:23.023 TCP socket to 141.14.128.12:5075 is to be closed.
2025-11-10T10:05:23.023 UDP socket 0.0.0.0:0 closed.
2025-11-10T10:05:23.023 UDP socket 141.14.128.70:5076 closed.
2025-11-10T10:05:23.024 UDP socket 141.14.143.255:5076 closed.
2025-11-10T10:05:23.024 UDP socket 169.254.104.63:5076 closed.
2025-11-10T10:05:23.024 UDP socket 169.254.255.255:5076 closed.
2025-11-10T10:05:23.024 UDP socket 224.0.0.128:5076 closed.
my:custom:pv
rtems:aSubExample
rtems:ai1
Unfortunately, reading the PVs doesn't work either:
(base) hactar:~ junkes$ env |grep EPICS_PVA
EPICS_PVA_ADDR_LIST1.14.128.12
(base) hactar:~ junkes$ pvget rtems:aiExample
Timeout
rtems:aiExample (base) hactar:~ junkes$ pvget my:custom:pv
Timeout
Does anyone have any idea what I'm overlooking?
Danke Heinz
Fritz-Haber-Institut  | Phone: (+49 30) 8413-4270
Heinz Junkes          | VC: https://zoom.fhi.berlin/junkes
Faradayweg 4-6        | Visitors: Hittorfstrasse 29 (Bld S (Slough House) )
D - 14195 Berlin
“Sorry I’m a bit late, had a terrible time…
All sort of things cropping up at the last moment. Uh, how are we for time?”
—Zarquon's address to Milliways
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: pvxs Access/list problem Michael Davidsaver via Tech-talk
Prev: areaDetector fft of subsection of image Jörn Dreyer via Tech-talk
Next: Re: areaDetector fft of subsection of image Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: areaDetector fft of subsection of image Mark Rivers via Tech-talk
Next: Re: pvxs Access/list problem Michael Davidsaver via Tech-talk
