1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: caget: Identical process variable names on multiple servers
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Paul Sichta <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 10 Nov 2025 21:01:50 -0600
On 11/10, Paul Sichta wrote:
> Lewis,
Hi, Paul!
Thank you for your reply.
> For the  "Identical PV" message:
> Is there a gateway on the 10.0.9 subnet that could be using ioc23 as a
> client?
No.  However, there is a CA gateway on 192.168.0.2, which is provided by
the APS, and which is listed in EPICS_CA_ADDR_LIST; ioc23 connects to
that for some PVs.  Could that be a problem?
(And of course, the strange thing is that this is very rare.  Out of
thousands of times running this command, it failed just this one time.)
> Your  10.0.9.255  is a broadcast.
>   0.0.0.2:5, is not in your ADDR_LIST,  so why is it answering your call?
Indeed.  And the same for 0.0.0.1:5.  I have no idea what that is.  The
0.0.0.0/8 network doesn't even exist on my infrastructure.
Lewis
Re: caget: Identical process variable names on multiple servers Guruswamy, Tejas via Tech-talk
caget: Identical process variable names on multiple servers J. Lewis Muir via Tech-talk
Re: caget: Identical process variable names on multiple servers Paul Sichta via Tech-talk
Prev: Re: pvxs Access/list problem Heinz Junkes via Tech-talk
Next: Re: pvxs Access/list problem Heinz Junkes (FHI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: caget: Identical process variable names on multiple servers Paul Sichta via Tech-talk
Next: Re: caget: Identical process variable names on multiple servers Guruswamy, Tejas via Tech-talk
