1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: mtca-evr-300rf,mrfioc2:failed to find/create object
To: [email protected]
Date: Sat, 29 Nov 2025 13:09:14 +0800 (GMT+08:00)
Hello, I'm trying to use the mtca-evr-300rf with the GTX inhibit function, but I can't control the GTX output. Could you offer some assistance?
When I run the command, the following prompt appears:
#!bin/linux-x86_64/mrf
dbLoadDatabase("dbd/mrf.dbd")
mrf_registerRecordDeviceDriver(pdbbase)
mrmEvrSetupPCI("EVRF","slot=10")
Notice: devPCIFindSpec() expect B:D.F in hex
Device EVRF  5:0.0 slot=10
Using IRQ 215
FWVersion 0x18200207
Found version 519
Found SFP EEPROM
Sequencer capability detected
mTCA:  Model mTCA-EVR-300 Pul 24 PS 8 OFP 4 OFPUNIV 4 ORB 10 OBack 8 OFPDly 2 CML 2 Kind 0 IFP 58
EVR FIFO task start
Enabling interrupts
dbLoadRecords("db/evr-mtca-300rf.db", "P=TST{EVRF, ES="}", EVR=EVRF")
macLib: macro ON is undefined (expanding string # It will be removed in future versions. Please use evrMrmApp/Db/mrmevrout.db $(ON)FineDelay-SP and $(ON)FineDelay-RB instead.
WARNING: 'db/evr-mtca-300rf.db' line 30772 has undefined macros
WARNING: 'db/evr-mtca-300rf.db' line 30854 has undefined macros
mrmEvgSetupPCI("EVG","slot=8")
Device EVG  c:0.0
Using IRQ 217
FPGA version: 280e0207
mTCA-EVM-300 #Inputs FP:3 UV:16 TB:16 BP:8
EVM automatically creating 'EVG:FCT', 'EVG:EVRD', and 'EVG:EVRU'
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Warning: Recommended minimum firmware 2 version is 207.6, found 207.0
Found SFP Strangeness 00000000
VME 64:  Model EVRD Pul 16 PS 3 OFP 8 OFPUNIV 0 ORB 0 OBack 0 OFPDly 0 CML 0 Kind 1 IFP 8
EVR FIFO task start
VME 64:  Model EVRU Pul 16 PS 3 OFP 8 OFPUNIV 0 ORB 0 OBack 0 OFPDly 0 CML 0 Kind 1 IFP 8
EVR FIFO task start
PCI interrupt connected!
dbLoadRecords("db/mtca-evm-300.db", "SYS=TST, D=EVG, EVG=EVG")
iocInit()
Starting iocInit
## EPICS R7.0.9.1-DEV
## Rev. 2025-07-11T16:00+0800
## Rev. Date build date/time:
TST{EVRF-Out:FPUV2}Freq:Init-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Freq:High-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Freq:Low-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV3}Freq:Init-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Freq:High-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Freq:Low-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPSFP}Freq:Init-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Freq:High-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Freq:Low-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPCML}Freq:Init-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Freq:High-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Freq:Low-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPUV2}Ena-SP: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18
TST{EVRF-Out:FPUV3}Ena-SP: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19
TST{EVRF-Out:FPSFP}Ena-SP: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20
TST{EVRF-Out:FPCML}Ena-SP: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21
TST{EVRF-Out:FPUV2}Ena-Sel: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Pwr-Sel: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Rst-Sel: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Freq:Lvl-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Pat:WfCycle-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV3}Ena-Sel: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Pwr-Sel: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Rst-Sel: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Freq:Lvl-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Pat:WfCycle-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPSFP}Ena-Sel: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Pwr-Sel: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Rst-Sel: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Freq:Lvl-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Pat:WfCycle-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPCML}Ena-Sel: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Pwr-Sel: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Rst-Sel: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Freq:Lvl-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Pat:WfCycle-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPUV2}Src-RB_: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18
TST{EVRF-Out:FPUV2}Src2-RB_: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18
TST{EVRF-Out:FPUV3}Src-RB_: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19
TST{EVRF-Out:FPUV3}Src2-RB_: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19
TST{EVRF-Out:FPSFP}Src-RB_: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20
TST{EVRF-Out:FPSFP}Src2-RB_: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20
TST{EVRF-Out:FPCML}Src-RB_: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21
TST{EVRF-Out:FPCML}Src2-RB_: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21
TST{EVRF-Out:FPUV2}Mult-I: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Freq:Init-RB: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Freq:High-RB: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Freq:Low-RB: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV3}Mult-I: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Freq:Init-RB: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Freq:High-RB: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Freq:Low-RB: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPSFP}Mult-I: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Freq:Init-RB: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Freq:High-RB: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Freq:Low-RB: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPCML}Mult-I: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Freq:Init-RB: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Freq:High-RB: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Freq:Low-RB: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPUV2}Src-SP: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18
TST{EVRF-Out:FPUV2}Src2-SP: failed to find/create object 'EVRF:FrontUnivOut18' : Object not found : EVRF:FrontUnivOut18
TST{EVRF-Out:FPUV3}Src-SP: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19
TST{EVRF-Out:FPUV3}Src2-SP: failed to find/create object 'EVRF:FrontUnivOut19' : Object not found : EVRF:FrontUnivOut19
TST{EVRF-Out:FPSFP}Src-SP: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20
TST{EVRF-Out:FPSFP}Src2-SP: failed to find/create object 'EVRF:FrontUnivOut20' : Object not found : EVRF:FrontUnivOut20
TST{EVRF-Out:FPCML}Src-SP: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21
TST{EVRF-Out:FPCML}Src2-SP: failed to find/create object 'EVRF:FrontUnivOut21' : Object not found : EVRF:FrontUnivOut21
TST{EVRF-Out:FPUV2}Mode-Sel: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV3}Mode-Sel: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPSFP}Mode-Sel: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPCML}Mode-Sel: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPUV2}Pat:Rise-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Pat:High-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Pat:Fall-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Pat:Low-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Pat:Wf-SP: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV2}Pat:Wf-RB: failed to find/create object 'EVRF:CML2' : Object not found : EVRF:CML2
TST{EVRF-Out:FPUV3}Pat:Rise-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Pat:High-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Pat:Fall-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Pat:Low-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Pat:Wf-SP: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPUV3}Pat:Wf-RB: failed to find/create object 'EVRF:CML3' : Object not found : EVRF:CML3
TST{EVRF-Out:FPSFP}Pat:Rise-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Pat:High-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Pat:Fall-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Pat:Low-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Pat:Wf-SP: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPSFP}Pat:Wf-RB: failed to find/create object 'EVRF:CML4' : Object not found : EVRF:CML4
TST{EVRF-Out:FPCML}Pat:Rise-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Pat:High-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Pat:Fall-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Pat:Low-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Pat:Wf-SP: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
TST{EVRF-Out:FPCML}Pat:Wf-RB: failed to find/create object 'EVRF:CML5' : Object not found : EVRF:CML5
Set EVR mTCA-EVR-300 EVRF clock 124915909.090909 newfrac 160334182 (oldfrac 127812077)
Set EVR EVRU EVG:EVRU clock 124916000.000000 newfrac 160334182 (oldfrac 0)
Set EVR EVRD EVG:EVRD clock 124916000.000000 newfrac 160334182 (oldfrac 0)
Prev: Re: Streaming from quadEM to HDF5 Mark Rivers via Tech-talk
Next: RE: mtca-evr-300rf,mrfioc2:failed to find/create object Di Wang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: Newbie question about SNL Mark Rivers via Tech-talk
