1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice
To: "Mark Rivers" <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 8 Jan 2026 16:07:54 +0800 (GMT+08:00)
Hi Mark,
Is the CRC-16/modbus by default using big-endian or little-endian order? Can the IOC developers set this parameter?
The CRC of my device uses little-endian order.
Gao Zhenhua
-----原始邮件-----
发件人: "Mark Rivers" <rivers at cars.uchicago.edu>
发送时间: 2026-01-08 10:48:20 (星期四)
收件人: 高振华 <gaozh at ihep.ac.cn>
抄送: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
主题: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice
Hi Gao,
Yes, it uses the only CRC method defined in the Modbus standard, as shown on page 14 is this official Modbus standard document:
Yes, because that is the only CRC check defined in the Modbus standard.
As far as I know that is not allowed by the Modbus standard.  Do you know of a real Modbus device that uses that?
There is an example IOC here with many example startup scripts.
The choice between TCP, RTU, and Serial ASCII is done by simply setting the linkType to 1 in the modbusInterposeConfig command as explained here:
Sent: Wednesday, January 7, 2026 8:09 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice
Hi Mark,
Does this Modbus driver use the CRC-16/Modbus check method?
How to set whether CRC uses big-endian or little-endian?
Does this driver only support CRC-16/Modbus check?
If other CRC check methods need to be used, how to set it? (For example: CRC-16/IBM)
Is there an example of a Modbus RTU IOC with this Modbus driver?
The parameters of CRC-16/Modbus required for the device I am communicating with are:
POLY(HEX): 8005
INIT(HEX): FFFF
XOROUT(HEX): 0000
Gao zhenhua
-----原始邮件-----
发送时间: 2026-01-07 20:38:29 (星期三)
收件人: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, 高振华 <gaozh at ihep.ac.cn>
主题: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice
Hi Gao,
For this type of Modbus communication you might want to use the EPICS Modbus driver rather than StreamDevice.  It will do those conversions for you.  It is also much simpler and more efficient if you want to read or write a number of bits or registers in a single I/O operation.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of 高振华 via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, January 7, 2026 3:53 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice
Hi all,
I am conducting Modbus RTU communication with a device and need to convert a 32-bit floating-point number into 4 bytes of hexadecimal data and then send it to the device.
For example: 3.15 converted to 4 bytes is 40 49 99 9A (in hexadecimal, big-endian order, ABCD order).
Using StreamDevice, how should I convert to the CDAB order? (For example, the CDAB order corresponding to 3.15 is 99 9A 40 49).
Does StreamDevice have a corresponding conversion symbol?
Best regards,
Gao Zhenhua
BSRF
Email:gaozh at ihep.ac.cn
祝好!
高振华
电话:010-88235426
祝好!
高振华
电话:010-88235426
The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice 高振华 via Tech-talk
Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice Mark Rivers via Tech-talk
Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice 高振华 via Tech-talk
Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice Mark Rivers via Tech-talk
Prev: PVXS release 1.5.0 and P4P 4.2.2 Michael Davidsaver via Tech-talk
Next: Re: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice 高振华 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice Mark Rivers via Tech-talk
