1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Archiver Appliance stuck on initial sampling
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Sat, 10 Jan 2026 09:45:46 +0100
Hm...
@Sky: Is there an explanation for these suspiciously even numbers of PVs with pending meta info compilation and pending search requests?
Cheers,
~Ralph
On Fri, 9 Jan 2026 at 16:55, Dennis Hilhorst via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi Sky,
Thanks for you quick reply! Most PVs are PVA and CA. They are not submitted with a pva:// prefix, though the archiver does seem to detect they are PVA. I restarted the archiver after clearing out all data again and submitted all PVs which are not from a python softioc. They are all from a single ioc running on the same host as the archiver itself, so the subnet should be okay. I have let it run for a few hours, but it still seems to get stuck. All PVs that “may not exist” and are not in the START state are in the METAINFO_GATHERING state, though the PV’s that are currently in the METAINFO_REQUESTED state report does show 1000 PVs, but I can’t abort from there. They seem to be a rather random assortment of PVs, and I don’t see a very common theme between them besides the values that are in the report: all of them say “false” for Monitoring started, and the other values (When, Remaining, Timer Done, Events so far, storage so far and Internal State and all the MainMeta values) are all N/A, 0 or null (the initial values?).
The repo you posted seems to unreachable from outside your facility maybe? I will try to tune these settings after the weekend to see if they have an effect.
Sincerely,
Dennis Hilhorst
RE: Archiver Appliance stuck on initial sampling Sky Brewer via Tech-talk
RE: Archiver Appliance stuck on initial sampling Dennis Hilhorst via Tech-talk
Prev: RE: Archiver Appliance stuck on initial sampling Dennis Hilhorst via Tech-talk
Next: Problems with clang under MacOS Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: Archiver Appliance stuck on initial sampling Sky Brewer via Tech-talk
