1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Re: Archiver Appliance stuck on initial sampling
From: Sky Brewer via Tech-talk <tech-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 13 Jan 2026 09:04:25 +0000
Hey Ralph,
Yes, the archiver has a rate limit for searching for the meta info of a thousand by default:
# org.epics.archiverappliance.mgmt.MgmtRuntimeState.archivePVWorkflowBatchSize = 1000
And then the meta channels, I just reckon they are all the same type of PV with 7 meta channels each. The meta channel list depends on your policy file, but I think this is probably all the alarm ones, HIHI, HI, etc.
There is a separate limit for the meta channels search:
# org.epics.archiverappliance.engine.metachannels_to_start_at_a_time = 10000
There are no meta channels if using PVA (which means lots of functionality PVA to CA is different for the meta data).
Hope that helps
Sky
Prev: Re: Problems with clang under MacOS Torsten Bögershausen via Tech-talk
Next: Re: Archiver Appliance stuck on initial sampling Sky Brewer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Archiver Appliance stuck on initial sampling Sky Brewer via Tech-talk
Next: Problems with clang under MacOS Torsten Bögershausen via Tech-talk
