1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Error message of StreamDevice while making it.
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Peter Sx <xinss0017 at gmail.com>
Cc: "Xin, Susheng" <sxin at bnl.gov>
Date: Wed, 14 Jan 2026 19:11:07 +0000
Hi Susheng,
Note that you don't actually need to build streamApp in order to use StreamDevice in your IOCs. It is just an example IOC.  I simply comment out this line in the top-level Makefile.
#DIRS += streamApp
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Peter Sx via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, January 14, 2026 9:14 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Cc: Xin, Susheng <sxin at bnl.gov>
Subject: Error message of StreamDevice while making it.
Good Morning,
I got errors while I am install the StreamDevice. Does the asyn verion cause the problem. I am using the asyn R4-46 from github. Thank you!
Susheng
/usr/bin/ld: streamApp_registerRecordDeviceDriver.o: in function `_GLOBAL__sub_I_streamApp_registerRecordDeviceDriver':
/usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt16ArrayAai'
/usr/bin/ld: streamApp_registerRecordDeviceDriver.o: in function `__static_initialization_and_destruction_0':
/usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynFloat32ArrayAai'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt32ArrayAai'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynFloat64ArrayAai'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt64ArrayAai'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt8ArrayAao'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt16ArrayAao'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynFloat32ArrayAao'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt32ArrayAao'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynFloat64ArrayAao'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:109: undefined reference to `pvar_dset_asynInt64ArrayAao'
/usr/bin/ld: /usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64/streamApp_registerRecordDeviceDriver.cpp:320: undefined reference to `pvar_dset_asynInt8ArrayAai'
collect2: error: ld returned 1 exit status
make[2]: *** [/usr/lib/epics//configure/RULES_BUILD:227: streamApp] Error 1
make[2]: Leaving directory '/usr/lib/epics_support/StreamDevice/streamApp/O.linux-x86_64'
make[1]: *** [/usr/lib/epics//configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/usr/lib/epics_support/StreamDevice/streamApp'
make: *** [/usr/lib/epics//configure/RULES_DIRS:85: streamApp.install] Error 2
RE: Error message of StreamDevice while making it. Xin, Susheng via Tech-talk
Error message of StreamDevice while making it. Peter Sx via Tech-talk
Prev: Re: Error message of StreamDevice while making it. Zimoch, Dirk via Tech-talk
Next: RE: Error message of StreamDevice while making it. Xin, Susheng via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
