1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: "lvhh at sari.ac.cn" <lvhh at sari.ac.cn>, tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 16 Jan 2026 19:55:43 +0000
Hi!
As an answer to both of your questions, I think you could take a look at https:// mdavidsaver.github.io/pscdrv/
I'm a big fan of network protocols due to avoiding custom drivers or complicated hardware interaction, and for enabling decoupling between devices and servers (location, architecture, hardware features, etc). For occasionally reading from a ~4MB device buffer, GigE should be fast enough (1/30 of a second... how often are you planning on transmitting that waveform?).
Cheers,
Érico
On 1/16/26 6:39 AM, lvhh--- via Tech-talk wrote:
Dear all,
We have a custom device generating 500k-point waveform data (float32/float64 arrays) and need to convert it to EPICS PVData for system integration. We seek guidance on two key points:
1.What communication protocol should the custom device support? Given the large waveform size, we prioritize high throughput, low latency, and structured data (to bundle waveform + metadata like timestamps/units). We wonder which standard industrial protocols are suitable? (e.g. VISA, GigE)
2. Which EPICS modules/tools simplify communication?
The data does not require real-time monitoring. Our local device has a cache, and data can be retrieved from the cache to be stored as EPICS PVs.
Any  documentation references are greatly appreciated!
Best regards,
Huihui
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS lvhh--- via Tech-talk
Prev: IOC does not pool network link PVs? Kasemir, Kay via Tech-talk
Next: Re: Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS Sukhanov, Andrei via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Query: Protocol & Module Recommendations for 500k-Point Waveform Data Integration into EPICS lvhh--- via Tech-talk
