1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [External] Re: Bacnet/IP to Modbus TCP Gateway Hardware Recommendations
From: William Jamieson via Tech-talk <tech-talk at aps.anl.gov>
To: "Heinz Junkes (FHI)" <junkes at fhi-berlin.mpg.de>
Cc: tech-talk at aps.anl.gov
Date: Wed, 21 Jan 2026 07:21:50 -0500
Heinz,
Thank you for the recommendation. We are considering using the MOXA 5217 gateway to set the BACnet values to "read only" before passing them onto EPICS as MODBUS records. This will be our method to prevent accidental write operations from EPICS, which are undesirable in our application.
William Jamieson
PPPL I&C Engineer
On Fri, Jan 16, 2026 at 7:49 AM Heinz Junkes (FHI) <junkes at fhi-berlin.mpg.de> wrote:
Hi William,
to communicate with BACnet we are using the epics BACnet:
https://github.com/ornl-epics/BACnet.git
Heinz
> On 16. Jan 2026, at 12:22, William Jamieson via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Has anyone had positive/negative experiences with any of the Bacnet/IP to Modbus TCP gateway hardware units out there? We are considering the one below for use with the asyn modbus driver for EPICS.
> https://www.moxa.com/en/products/industrial-edge-connectivity/protocol-gateways/modbus-tcp-gateways/mgate-5217-series
> Any and all thoughts are appreciated!
> William Jamieson
> PPPL I&C Engineer
Bacnet/IP to Modbus TCP Gateway Hardware Recommendations William Jamieson via Tech-talk
Re: Bacnet/IP to Modbus TCP Gateway Hardware Recommendations Heinz Junkes (FHI) via Tech-talk
Prev: Re: Configuration of the RGA200 communication baud rate Eric Norum via Tech-talk
Next: IOCStats 4.0.0 Released Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Bacnet/IP to Modbus TCP Gateway Hardware Recommendations Heinz Junkes (FHI) via Tech-talk
Next: New oac-tree release v1.3 Van Herck Walter via Tech-talk
